CPU Oscillator fell out of motherboard
Jury
I recently purchased a cheap motherboard from ebay. I open the box, and it looks as pictured. Then I see it in the bottom of the box...
Something that looks exactly like that.
Can I fix this somehow? or should I just try to get a refund?
just re-solder it
although TBH id just gets refund
Ultimate XP gaming system build log coming soon!  Q8200 // 8GB DDR2 // Asus P5E Deluxe X48 // Asus 4870 DARK KNIGHT X-Fire // Supreme FX sound // BFG Ageia PhysX PCI Co-Processor // AX 860x with Silverstone extensions
If you are lucky you can solder it
refund it if just purchased
any attempts to DIY and getting it back to work will void your warrany
if you attempt to solder it back - best case scenario it Works but you still voided your warranty for future issues
worst case scenario - the oscilator is dead eitherway and you just voided you warranty and are stuck with a usless, broken  circuitboard
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
I could fix it pretty easy, if I could tell what the picture is
Will it POST without the crystal in place?
http://www.nix.ru/autocatalog/motherboards_gigabyte/53840_top.jpg
Its the one by the golden gigabyte thing.
Does that make a difference?
starting to wonder if the top of the cap popped off. Those usually arent surface mount
Wait , i though cpus didn't have crystal/quartz oscillators for the clock anymore !?
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
