Battery powering Pi
I have a 3200mAh battery (5V, max 2.1A output) and it runs my Pi for about three or four hours. Granted, it's an original Pi B, so it has a lower max power draw (1A vs 2A for Pi 2s), but it still works for a little while.
If you have a battery pack, just make sure it's got the right amperage output. But be wary: I don't know if most battery packs are designed to work as PSUs for things like this. A phone charger or a battery pack might not provide a stable 5V 2A, since you don't care about that when you're just charging a battery. This might only be a problem if your Pi is doing some really heavy-duty stuff and drawing nearly the max current, though. As long as your battery pack is rated for a little more amperage than the Pi's max draw you should be fine.
