Pfsense Need some help deciding
Solved by Altecice,
So basic i was never into network , and because of that everything is new to me .
Its intresting for me if pfsense squid cache improve internet speed on devices or download speeds on steam ?
and another if it worth to spend money and build router ? ( in your point of view )
Thanks !
1) No Squid Cache wont improve your internet/download speeds. Only your ISP can do that (by you paying for more)
2) If you dont know what you're doing, go do some research first... personally building a PFsense router is pointless, your ISP's does its job fine.
