it's waaaaay too hot at idle
https://linustechtips.com/topic/525365-too-hot/#findComment-6973156
Holy fuck thats at idle? whats it like on full load?
CPU: Intel Core i7-5820K @ 4.1GHZ | MOBO: Asus Rampage Extreme V Eatx LGA2011-3 | RAM: 16.00GB DDR4 G-Skills Ripjaws @2400Mhz | GPU: 2x Gtx 980 | CASE: Cooler Master Cosmos 2 | STORAGE: 400GB INTEL 750 Series PCI-E SSD/ 3TB Western Digital WDC | PSU: Corsair AXi 1200w | DISPLAYS: ASUS PB287Q (3840x2160@60Hz) And LG27MU67 (3840x2160@60Hz)
https://linustechtips.com/topic/525365-too-hot/#findComment-6973175
I wouldn't want to put any load on that!
My Build: Night Fury | i5-6600k @ 4.5Ghz | R9 390 | 850 EVO 250GB | 1TB Seagate | H230 Black
Night Theme User
         Hello Fellow Night Theme User | Why Aren't You Using Night Theme?
https://linustechtips.com/topic/525365-too-hot/#findComment-6973182
I Have an i3 2320M running at 2.2GHz i was wondering if 70c is too high  at idle or is the software im using rong
That's IDLING?! Holy shit, that's way too hot.
Other systems I've built:
https://linustechtips.com/topic/525365-too-hot/#findComment-6973184
nvm
https://linustechtips.com/topic/525365-too-hot/#findComment-6973187
that is not at idle
https://linustechtips.com/topic/525365-too-hot/#findComment-6973191
did you even look at the image???
do you see that little square beside "CPU" which is almost completely green???
that's CPU usage
https://linustechtips.com/topic/525365-too-hot/#findComment-6973205
that's CPU usage
isn't that the temp thing?
https://linustechtips.com/topic/525365-too-hot/#findComment-6973211
that is not idle and it's a laptop, it about right
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/525365-too-hot/#findComment-6973221
that's CPU usage
Thats temps. ive been using speccy for 4 years
https://linustechtips.com/topic/525365-too-hot/#findComment-6973230
you might be right, sorry
the motherboard has one too
he should show us task manager because even with a badly mounted cooler the temps wouldnt be this high, so im still fairly sure that the CPU is not at idle
https://linustechtips.com/topic/525365-too-hot/#findComment-6973240
That's a laptop sooo.
https://linustechtips.com/topic/525365-too-hot/#findComment-6973253
I'd say that is WAYYY too hot at idle, but I have no idea if that program is accurate. Go download the tril version of AidaExtreme and see what it tells you. I have found that matches my BIOS temps pretty well.
If Tjmax is the temp then it sys 85c if not then it dodnt say
https://linustechtips.com/topic/525365-too-hot/#findComment-6973290
Green bar is usage. Next to it are temps. Its not idle. Its general usage, which is fine. Also for laptop its normal.
Software used in pic is Speccy which is as good as any other known software.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/525365-too-hot/#findComment-6978697
