Corsair AF120 problem
SH_93
I'm not sure if this is the right spot to post this and i'm sorry of i'm wrong.
I bought 1x af 140 and 2x af 120.
The 140 went in fine, both the 120's however have there screws half in and now seem to be stuck.
Anyone with Any tip in how to solve this?
System: Intel Core i5-6600K | Cooler Master Hyper 212 EVO | MSI Z170A GAMING M7 | Kingston HyperX Fury Black 16GB DDR4-2133 | Samsung 850 EVO-Series 250GB | Western Digital Caviar Blue 1TB | MSI Radeon R9 390 8GB | EVGA 750W Supernova G2 |
DRILL!!!
Wouldn't that break it?
And i don't have a drill any other options?
Anyone?
Unscrew it and try again?
They are stuck not going in any further or coming out.
Tried it with a drill and it isn't moving
Make sure to push down on the screw for a firm grip.
Finaly managed to get the screws in with the drill, however one of the rubbers broke.
Waranty won't cover that or will it?
Probably. You can try contacting Corsair.
Next time if you're near a hardware store or if you have any, use nuts and bolts to fasten the fans. I have used fan screws for some AF120's and getting them in was a bitch, and the nuts and bolts was better.
Also make sure that the nuts and bolts are the correct size so you can get them through the fan mounting holes, otherwise you won't mount them well or at all.
Edited by JurunceNK
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
Will give it a shot, thanks for the help
I don't think that there is space for that with the bottom dust filter.
You can always find the bolts of reasonable length, if not you can dremel them to length. You can even try to secure it between the mounting holes with really short ones, but you'll need pliers to do that.
Also my recommendation is to get ones with the length of the threads at 40mm long so you can secure it to the case and that the nut can catch. And make sure you get the ones using the same thread type.
Edited by JurunceNK
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
