Does using the intergrated sound card make me retarded?
ToniBamboni
I'm using the msi sli krait mobo with the intergrated sound card. I'm purchasing some sennheiser hd598s and I a wondering if I need a dedicated sound card
CPU: Intel Xeon E3 1231 V3 3.4ghz CPU COOLER: Cryorig H7 w/ Red Corsair SP120mm  MOBO: MSI SLI Krait Edition Z170 MEMORY: G.Skill Ripjaws 8gb (2x4) Storage: Kingston V300 120gb, WD 1TB GPU: MSI R9 390X CASE: Phantom 410 (ew) PSU: Thermaltake Toughpower Modular 550w CASE FANS: 4 CORSAIR SP120mm MONITOR: LG 25UM67 KEYBOARD: Das4 Ultimate Cherry MX Blue MOUSE: Deathadder Chroma Left-Handed AUDIO: Sennheiser HD598 Black, Astro A40s
Moved to Audio.
Please post in the proper sub-forum next time.
No, it doesn't make you 'retarded'.
While a separate soundcard can sound better than the built in one, these days the built-in cards are actually really good, especially those on higher end motherboards.
"It's a taxi, it has a FARE METER."
Having a dedicated sound card would probably be a worse choice than using the onboard, as there's really no improvement when compared to modern onboard audio. If anything, get a decent external DAC. (not needed though)
No, modern integrated sound cards are really good. If you would actually get a sound card, it could be worse causing interference.
As others have said most sound cards sound worse or the same as the onboard ones. Your good :)
TX10 Build Log: http://linustechtips.com/main/topic/456229-tx10-build-log/
Case: TX10-D   Proccessor: i7-5820k   MotherBoard: Asrockx99 Extreme4   Ram: Crucial Ballistix Sport 16GB (DDR4-2400)   GPU: Asus Strix OC 980ti   Storage: 850pro 500gb, 850pro 500gb, 850pro 256gb, WD black 16tb total, Silicon Power S60 120GB   PSU: Seasonic snow silent 1050   Monitors: Three of Asus VG248QE 144Hz 24.0"
yes, definitely, by using your motherboards integrated sound you will almost certainly develop a cognitive disability
TekSyndicate made a video about it. Sound cards give you the same or worse audio, the only advantage is basicly the software which (may) be better
My Rig: AMD Ryzen 5800x3D | Scythe Fuma 2 | RX6600XT Red Devil | B550M Steel Legend | Fury Renegade 32GB 3600MTs | 980 Pro Gen4 - RAID0 - Kingston A400 480GB x2 RAID1 - Seagate Barracuda 1TB x2 | Fractal Design Integra M 650W | InWin 103 | Mic. - SM57 | Headphones - Sony MDR-1A | Keyboard - Roccat Vulcan 100 AIMO | Mouse - Steelseries Rival 310 | Monitor - Dell S3422DWG
You're probably fine. I only have an MSI Z97 PCMATE with HD 558s and no sound card...
¢υѕтσм ℓσσρ σя ησтнιηg αт αℓℓ
Have a 1k dac/amp setup... If anything I'm the retarded one since I felt it's the same as my old o2+odac setup for tripled the price. Though money isn't exactly tight, and it gives me ease of mind that there's no bottleneck in my audio chain.
Sound cards are a joke now since pretty much every gaming MB manufacturer includes 7.1 onboard audio. Unless you're doing professional audio recording there's no point in investing.
The days of sound cards are dying out slowly. The HD598 is easy to drive, and doesn't need a amp and a sound card would probably be a con for you, since on board audio solutions are better than a decade ago. Of you plan on getting anything, I'd suggest a DAC of some sort.
Like watching Anime? Consider joining the unofficial LTT Anime Club Heaven Society~ ^.^
