Posted January 2, 2016 Okay so I've had this issue ever since i got the game on release. I have a fairly good Gaming PC that can run most games on high, no issues, with a stable 60-50fps. (ex. Skyrim, Far Cry 3, Black Ops 3, CSGO, Tf2, Witcher 3) Although Fallout 4 has some trouble floating around the 30-40 region on ANY graphical preset. I don't know why, I know that my CPU isn't bottlenecking my GPU because I checked the CPU and GPU usage while playing FO4 and they are both on max load. (though for some reason they run surprisingly cool at around 30-40c) Maybe its because my system is an AMD build? I honestly don't know. If you guys have any suggestions, or you had this exact problem, please let me know. (and yes I've tried FPS configs, they run exactly the same) My Specs: CPU: AMD FX-6300 Motherboard: ASUS M5A97 R2.0 GPU: Sapphire Radeon R9 380 PSU: Corsair CX750M HDD: WD Caviar black 650Gb RAM: Crucial DDR3 8gb (2x4) (idk the exact name of the ram) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2016 FO4 just doesn't like AMD. Computing enthusiast. I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 2, 2016 I still think it CPU issues... I just recently switched from FX6300 to I7 6700k and fallout 4 runs much better than before. No longer it has frame drops to low 20 and it much smoother game play. Have you tried updating your graphic card drivers? You sure changing your settings to all low doesn't help with your frame rate? So the fact fallout 4 is kinda more CPU intensive due the old engine. http://www.gamersnexus.net/game-bench/2182-fallout-4-cpu-benchmark-huge-performance-difference Magical Pineapples
