Where to get replacement o-ring fast
Solved by W-L,
So I either lost or one of my fittings shipped without an o-ring around the g1/4 attachment. It is this fitting in particular. I'm assuming these are all standard & are interchangeable? Where can I get a replacement really fast? (PPCs is in my state, but all orders will be on hold until the 4th).
Really frustrating. Finally got my loop together after 18hrs or so of work, only to have it leak right at the pump/res while filling it up for the first flush. Now I'll have to disassemble everything to check all the o-rings & wait for a replacement.
You can get one that is the same size at the hardware store store if you don't want to wait, I would bring the old one to compare just to make sure.
