Temps while playing
Go to solution Solved by Mug,
Your cooling is clearly fine. These are good temperatures.
Here are my temperatures while playing Witcher 3.
CPU: Going 63°C
GPU: Going 75°C
My specs are listed on my signature.
Are those temperatures just fine? Or should I get a better cooling? I dont have much budget so I'd appreciate to get expert opinion if it's fine to leave it just be.
Witcher3 gives good stress to my pc right? So if I play other games it wont exceed those temperatures right?
CPU: Ryzen 7 5800X | MOBO: Gigabyte B550 Vision D | RAM: Crucial Ballistix RGB 32GB 3600MHz | GPU: Gigabyte RTX 3070 Vision D | PSU: Seasonic Focus+ Gold 750W
https://linustechtips.com/topic/515815-temps-while-playing/
that's a bit warm for a CPU
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/515815-temps-while-playing/#findComment-6860258
CPU: Going 63°C
GPU: Going 75°C
Perfectly fine for the GPU! The CPU is a little warmer than I would expect for a i5 but it totally 100% safe!!!
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
https://linustechtips.com/topic/515815-temps-while-playing/#findComment-6860266
CPU looks fine and amd gpu are warm
depending on airflow in the case you might could go a few °C lower depending on your setup
CPU i7 4790K 4,7Ghz Cooling:Corsair H100iGTX+Noctua NF-F12PWM GPU: EVGA 1080ti SC+ ACX2.0+ RAM:16GB DDR3 1866mhz Crucial Balistics Tactical Tracer Mobo:ASUS Z97-AR PSU:EVGA 750W G2 Supernova Case:Fractal Meshify C Storage:500GB Samsung 850 evo, 900GB Toshiba Game Storage SSD, 2TB Data HDD
i7 4790k Devils Canyon OC @4,6Ghz,Cooler Corsair h100i GTX, GPU EVGA 980Ti SC+ ACX 2.0+ @ stoc
http://linustechtips.com/main/topic/278610-display-technology-faqmythbuster/
https://linustechtips.com/topic/515815-temps-while-playing/#findComment-6860270
280X is a hot card so that's fine, the CPU is a little toasty though but below limits
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/515815-temps-while-playing/#findComment-6860272
It's fine.
Stock Coolers are that way.
You can get a Hyper 212 evo for cheap and cool it better.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/515815-temps-while-playing/#findComment-6860274
Totally fine, don't worry.
I dont have much budget so I'd appreciate if I can maintain my performance without spending or at least spending the minimum.. Thanks for the input..
https://linustechtips.com/topic/515815-temps-while-playing/#findComment-6860276
How much do you have? What case do you have? Are your heatsinks and fans clean?
A picture could help here
Ryzen Ram Guide
https://linustechtips.com/topic/515815-temps-while-playing/#findComment-6860288
with a low budget you can do something too ;)   you only need air and something to guide it
maybe draw something in paint to show your fan-setup                         ( push / pull )
https://linustechtips.com/topic/515815-temps-while-playing/#findComment-6860296
It's fine.
Even though my CPU is a bit warm it wont change its performance even if I get coolers right? So i'd prefer not to purchase one. But if you can say that it will affect the performance then definitely I'd get one.
Thanks everyone.
https://linustechtips.com/topic/515815-temps-while-playing/#findComment-6860300
the cpu is fine for beeing stock cooled, no cooler won't affect Performance but its just nicer to Keep them as cool as possible, since you get longer lifespan out of your chip. But your temps are 100% fine so don't worry
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/515815-temps-while-playing/#findComment-6860321
Thanks everyone.
It'll be the same performance even at that temp.
But if you get a better cooler, it'll be safe. longer CPU life. less heats produced.
https://linustechtips.com/topic/515815-temps-while-playing/#findComment-6860322
Wait i'll upload picture of my casing including the Fan Orientation.. Maybe i'll create another thread so topics and replies doesnt jumble.
https://linustechtips.com/topic/515815-temps-while-playing/#findComment-6860324
fine temps
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/515815-temps-while-playing/#findComment-6860333
http://linustechtips.com/main/topic/515825-my-case-airflow-are-they-doing-good/
Here's the link of the thread. I posted picture of my set-up. Thank you.
https://linustechtips.com/topic/515815-temps-while-playing/#findComment-6860464
Thanks everyone.
Aftermarket coolers help most in OC and noise situations. It will bring your max temps down some too. But in the end if you aren't having overheating issues, not getting aftermarket cooler for non-K CPU is fine too.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/515815-temps-while-playing/#findComment-6868148
