too much thermal paste?
i'm pretty sure I accidentally put too much thermal paste on my 4790K hits 80C at 100% not overclock and when I overclock it too 4.6GHz it's gets to 100C... So how do I clean thermal paste off?
      CPUIntel Core i7-4790K 4.8GHz Moherboard: MSI Z97 SLI Krait Edition Memory: HyperX FURY White 24GB DDR3 1866MHz GPU: Asus GTX 970 Turbo
             PSU: EVGA SuperNOVA 750w SSD: Crucial MX200 250GB HDDWB Blue 1TB Monitor: (2x) BenQ GL2460HM 24-Inch Case: NZXT S340 White
https://linustechtips.com/topic/514914-too-much-thermal-paste/
i'm pretty sure I accidentally put too much thermal paste on my 4790K hits 80C at 100% not overclock and when I overclock it too 4.6zGHz it's gets to 100C... So how do I clean thermal paste off?
Use isopropyl alcohol to clean the thermal paste off the CPU,.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/514914-too-much-thermal-paste/#findComment-6850262
https://linustechtips.com/topic/514914-too-much-thermal-paste/#findComment-6850265
rubbing alcohol
mr clean
lysol
brake cleaner
carburator cleaner
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/514914-too-much-thermal-paste/#findComment-6850266
99.99% alcohol or 70% works as well.
Apple tho...
~~~SnapDragon~~~
| CPU: AMD Ryzen 9 9950X3D | CPU Cooler: Gigabyte Aorus Waterforce X II 360mm |RAM: 2x32GB G.Skill Trident Z5 Neo RGB 6000MHz | Mobo: Gigabyte X870E Aorus Xtreme X3D AI Top  | Storage: Samsung 9100 Pro 4TB + Samsung 990 Pro 4TB + Samsung 870 Evo 4TB + Samsung 870 Evo 2TB | Graphics Card: Gigabyte RTX 5090 Aorus Master 32G | Case: Lian Li Lancool 216 | PSU: Seasonic Vertex GX-1200 |
https://linustechtips.com/topic/514914-too-much-thermal-paste/#findComment-6850294
Apple tho...
Just curious, can I see your source?
A society's accepted views of the world surrounding said society is both the making and undoing of society itself.
“While one person hesitates because he feels inferior, the other is busy making mistakes and becoming superior.” - Henry C. Link
https://linustechtips.com/topic/514914-too-much-thermal-paste/#findComment-6850350
It's the first picture on a google search for "apple too much thermal paste". Apparently, it's taken from the Apple Service Manual.
~~~SnapDragon~~~
https://linustechtips.com/topic/514914-too-much-thermal-paste/#findComment-6850371
You are supposed to use rubbing alcohol to clean it off. But I have literally used my shirt to clean off my CPU LOL (Please don't do that).
Yeah, don't do that if you don't want stains. I just use a paper towel.
https://linustechtips.com/topic/514914-too-much-thermal-paste/#findComment-6854866
our source: experience.
it is the best stuff to use..
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/514914-too-much-thermal-paste/#findComment-6854874
unless you put waaaaaay too much on there, you shouldnt be hitting those temps.  is it possible your heatsink just isnt attached properly?
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/514914-too-much-thermal-paste/#findComment-6854964
I meant for the image of Apple putting that much paste on, which he answered already.
https://linustechtips.com/topic/514914-too-much-thermal-paste/#findComment-6855678
