Rebuilding PC for college NEED HELP
Solved by slasher0161,
Probably best sitting on what you currently have until you see the work load and find out if your system is falling behind, having now seen what your current setup is. The only thing with graphics design will be if the programs you use prefer opencl or cuda based acceleration. What you must realize is these courses they have to cater to the masses and your current system is better than what most have, if you need a balls to walls system the college will let you know.
For gpu I would keep the 660 for now and wait. especially with 9000 series so close.
