Data segment:
array_size equ 5src_array db 01, 23, 45, 67, 89dst_array db array_size dup(0)
these are stored in bytes, it's enough for these values, change it out for whatever you need.
Code segment:
cp_loop:  mov bx, 0  mov al, src_array[bx]  mov dst_array[bx], al  inc bx  loop cp_loop
This is from the top of my head, I'm sure you can do it better. Also you might need to change the registers appropriately, since this is for the Intel8086, the one I have most experience writing Assembly for.
https://linustechtips.com/topic/507526-assembly-homework-help/#findComment-6775343
Assembly, otherwise he wouldn't have said assembly...
well duh, we figured that out when we came back to see if he replied.
You already knew we probably didn't know what assembly was so don't reply twelve hours later with redundant info implying we're idiots
Shipping sucks
https://linustechtips.com/topic/507526-assembly-homework-help/#findComment-6777618
