6 x 120mm or 4 x 140mm case fans
Clarifiante
hi there, i've got a phanteks enthoo evolv atx case. very sexy, love at first sight kind of moment
it can accommodate 3x120 or 2x140 in the front and on the top. and 1x140mm at the rear
i plan to install a kraken x61 radiator on the top.
being an absolute noob and assuming i dont care that much about noise (nothing industrial of course), which combination would provide better temperatures?
thanks!
Generally speaking 2 140mm fans at the same loudness generate about as much airflow as three 120mm fans.
I would personally say 140mm all the way.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
Go with the largest fans you can, that way they can run at a lower speed while moving roughly the same amount of air, which can make your PC a bit quieter as well.
Well it should be which ever has the most flow, which should be the 6 x 120 based on my calculations (just guessing based on total surface area)
4x 140mm's have more surface area than 6x 120mm's when disregarding the frame and hub which don't produce airflow.
not last time I checked... if we disregard the frame like you said, they are a circle.  Now:
6 * pi * (0.120m / 2)^2 = 0.067858 m^2
4 * pi * (0.140m / 2)^2 = 0.061575 m^2
Am I missing something?
The hub?
4(3.14 * 70 * 70 - 3.14 * 44 * 44) = 37227.84
6(3.14 * 60 * 60 - 3.14 * 42 * 42) = 34590.24
The hub?
Good point.  But I just measured mine and the hub isn't that big.  If the hub for both was 3 cm the 6 120s are still more.
OP, we need exact measurements :)
not too sure which measurements you're asking for but these are the case measurements:
230 mm x 495 mm x 510 mm (W x H x D) 9.25 in x 19.5 in x 20.1 in
Or you can just recognize that 140mm fans are much more efficient on a noise per airflow perspective, and are at least within the margins of error of overall airflow (assuming similar fan profiles which is a really bad assumption.)
We need the diameter of the solid part in the middle with no blades :P
The hub?
Because I realize we both just made another mistake, or vastly overestimated the hub.  With your calculation the hub would be 8.4 and 8.8 cm respectively - ie, most of the fan.  Definitely not :)  I threw in 30 instead of 44 but even that is too much since the hub is more like 15 (mm radius)
Yes 140 (or any larger fan) are generally better overall when taking everything into account, but if we just estimate based on the surface area (which has been started and must be finished now :P)
4(3.14 * 70 * 70 - 3.14 * 20 * 20) = 56520
6(3.14 * 60 * 60 - 3.14 * 20 * 20) = 60288
Whoops-- I messed up. I used the diameter of the hubs instead of the radius.
Also, after some measurements of a few fans, I found that hub sizes can vary a bit ranging from 38mm-42mm but are usually 40mm.
It seems that 120mm's do have more fan surface area. That being said, airflow is still a bit more complicated than just surface area since the edge of a fan blade will travel faster at the same rpm for a larger fan.
I was just typing up a response to that. Most hubs are ~40mm though--where are you getting fans with 30mm hubs?
My front fan.  The others are larger like you said (up to around 40) but like you said, they vary.  And, yes like I mentioned flow depends on a lot more than the total area, but the 120s would have more area.
these are the ones im looking at http://www.amazon.com/Cooler-Master-JetFlo-R4-JFDP-20PB-R1-Performance/dp/B00E20SSZ8
which come in at 120x120x25 with airflow of 95CFM so that brings it to 285 CFM intake
their airflow ensures that no combination of consumer 140mm can beat them. because im running a 280mm radiators i assume i dont have any choice but to run 2x140mm on top. and the 1x140mm rear is static.
the 140mm fans that come with the case are http://www.amazon.com/Phanteks-140mm-Cooling-Fan-PH-F140SP_BK/dp/B00E9NZV4Y/ref=sr_1_1?s=pc&ie=UTF8&qid=1449305356&sr=1-1&keywords=PH-F140SP
which come in at 140x140x25 with airflow of 82.1CFM, brings it to 246.3 CFM exhaust
so with this the intake > exhaust.
am i doing it right? lol
oh, not sure if this matters but the front intake has a filter
Jetflos do perform very well but they are also very loud.
if you have pwm headers get the venturi hp-14 fans as they are the best value to performance/quietness ive found
wan
