Dual monitor set up help!
LewisManslow
So I'm getting dual monitors this christmas, to be specific i am getting two Samsung Ls24d590. I have a gtx 760 and i just wondered what i would need to do to set it up etc, i know how to setup dual monitors in Windows and stuff but when i come to physically plugging them in I'm a little confused. Could someone please help me by telling me if i need any adapters or anything and where to plug it in etc. Thanks a lot and sorry if i am coming across as a noob haha.
A10 7850K (4.8GHZ) | Gtx 760 4GB | 16GB HyperX Fury White 2133mhz (OC) | A88XM-PLUS | Corsair CX 430 | Bit fenix Neos |
plug them both in to your GPU (it has 2 DVI outputs that will work nicely)
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
You will need two HDMI cables and an adapter to either DVI or DP
OR
One HDMI cable and an adapter to DVI
just plug then both into your GPU and that's it. then when you get on the desktop you can right click screen resolution and from there pick what is moniter 1 and 2 so when you mouse over to a certain side it goes to the other moniter how it should
Plug one with a HDMI cable into your GPU and Monitor
and
grab a DVI to HDMI adapter for the second monitor.
I think his main concern is that the monitors only accept HDMI and VGA input and his card only has one HDMI output.
oh, well, they make cables with HDMI on one end and DVI on the other
Solitaire.
well he can get a HDMI splitter or a a dvi to hdmi adapter. or whatever ports he has to a HDMI adapter
Just buy an HDMI to DVI cable from Amazon. Shouldn't be more than a few dollars, I've purchased a couple of them over time.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Thanks you so muvh everyone! This helped alot!
