Dual monitor on single GPU...?
Solved by Ostwind,
I think the display output on the motherboard is disabled when you're using a video card anyways.
Negative, I'm running my four displays split 2-2 between my GPU and my iGPU. More often than not you just need to enable multi-monitor iGPU in the bios. For some reason it's usually off by default.
Featured Topics
Pirateben ·
1
DietzDiet ·
Posted in Storage Devices2 -
LinuxPiThor ·
Posted in Linux, macOS and Everything Not-Windows0 -
frozensun ·
Posted in Laptops and Pre-Built Systems10 -
9
19
Vectraat ·
Posted in Phones and Tablets0 -
2
superbrett2000 ·
Posted in Cases and Mods7
