PROBLEM WITH INTEGRATED AND DEDICATED GRAPHICS(r9 390 and i5)
ama
So guys i have a serious problem...
I have a sapphire r9 390 and a i5 6600k with an Asus pro gaming mobo.(+ 16gb ram and a 550w psu)
When i connect directly my graphics card with an hdmi to my monitor my pc boots up, but only the r9 390 shows up in the setting etc i can use only it (and only catalyst control center shows up).
When i connect my monitor through the motherboards hdmi output onyl the i5s integrated gpu will work(Intel graphics settings load etc).
And when i try to put the hdmi cable while the pc is working in  the other hdmi slot the monitor turns black!
What should i do??
What should i do??
I don't understand the issue here. Is this not normal?
Other systems I've built:
Boot into the BIOS with the card connected and see if the iGPU is enabled or not. If it isn't, enable it.
Why are you trying to use both at the same time on a single monitor?
Well i want to use switchable graphics as on my notebook ... or why did i then bought an integrated gpu?
I always thought that the  r9 390 uses much more power when i use word chrome as the i5setc., so i wanted switchable graphics.
Why did you want switchable graphics? Switching away from the R9 390 when you aren't gaming will save you so little money it's not even worth calculating. Keep it plugged into the GPU all the time. The iGPU comes is a part of the i5 and it's only supposed to be used when you don't actually have a graphics card.
so i have enabled it... aand its kinda funny... now there is a virtual desktop even though i have only 1 monitor.. and when i turned it off the pc monitor turned off, so i had to plug it into the mobo's slot...and now the r9 390 doesn't work.
ok well i thought that would do sense to switch them..... but after all i dont understand why it isn't working even if i wouldn't use it...
A 390 uses roughly the same power at idle as surfing, YouTude jumps the watts up a few but nothing past a light bulb.
If anyone asks you never saw me.
ok guys thank you, i think i will just stick to my 390... however, i just don#t understand the purpose of an igpu then.... i read that even with multiple monitors it isn#t worth to du ipgu + dgpu together.... thats kinda lame
If you were worried about power usage, even though the power usage at idle would be negligible, you should have bought a GTX 970 instead.
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
:huh: What? For 40w at full load? At idle is what the discussion is on.
The integrated chip is for those without a GPU.
The integrated GPU is for those who don't have a graphics card. It makes no sense to try to use both at once.
ok i think i had a laptop to long....) THANK U ALL VERY MUCH I LOVE U! linus techtipsforum is seriously the best
I should have spaced out my statement differently.
The power usage at idle would be negligible. If you were that worried about power consumption, you should have gone for a GTX 970.
Incipere V5.0
Parvulus V1.0
That's just it, the funny thing is the 290 which uses 30w more than the 390 at full load, uses 20w less at idle. So load wattage and idle wattage are not connected in the least. While I save power using the 390 at full load, I lose power using the 390 at idle. I will get my hands on a 970 so as to test the living shit out of it, I bet I find similar findings and make this silly talk about efficiency obsolete.
The way OP is talking about this matter made it seem like power usage was a big deal, even at idle where power usage would be very low, regardless of the display adapter used. That's why I said if he was that worried, he should have gotten a 970.
I agree, the only time I would now recommend a GTX 970 to someone is if it was going in an SFF build.
Incipere V5.0
Parvulus V1.0
actually, he would prolly lose money, as AMD and Nvidias GPUs is extremely efficient at minimum clocks
at "idle" speeds, AMD and Nvidia is pretty much neck and neck.. we are talking just a few watts apart..
Worrying about the wattage used in a gaming rig is like worrying about the gas mileage of your Mustang. But if you really want to have that worry get a wattage meter, I got mine for 20 bucks. And I bet that's 3 years of running a 970 compared to a 390. IF that. And don't get me started on the difference between one monitor and two, WHICH NO ONE EVER MENTIONS WHEN THEY TALK ABOUT NVIDIA EFFICIENCY!!!
Sorry, that just drives me crazy. "I've got 3 monitors going and 15 LED fans but I won't run a AMD card, cuz efficiency."
