Simple monitor stand?
Guest
Just as a replacement for the standard stand that comes with your monitor, where can I get a cheap stand for a single monitor? Like the one in this pic.
http://imgur.com/a/BHA1u
Does your monitor have support for VESA mounts? If so you can literally google "vesa stands cheap" and literally get any of them.
If not i'd suggest getting some books bruh.
Yes of course it does :P
I'm not that stupid.
Arctic Cooling makes some nice ones.
Too expensive though :(
Dildo with VESA mount
The weird kid in the corner eating glue
“People think that I must be a very strange person. This is not correct. I have the heart of a small boy. It is in a glass jar on my desk.” - Stephen King
Hmmm ok..... What's your budget?
I'd say about 10-30 dollars. Don't really need swivel or rotation.
It'd fall down...
It'd fall down...
Maybe if it had a suction cup on the bottom or screwed it through the centre into the table
Sorry I can't remember any product in that price range.
But you can also DIY something as the construction is very simple.
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
He's 14. The fuck would he have a use for a dildo for.
his moms... Or maybe he just has one
