Scared of flying?
Overkilled
Im not usually scared of flying Id say im well travelled for my age but ive never been outside of Europe or on a flight more than a few hours. Im going to New york in about 12 days and all the stuff happening in France is making me a bit hesitant of flying on a 7 hour flight to the so called capital of the world
The odds of dying in a plane crash are very high, id rather drive.
I'm in the same boat really, I've never been out of Europe, furthest I've been is Cyprus. Honestly I wouldn't worry about going to New York, you're probably safer to fly now than at any other time, because airport security will be ridiculously high.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
I have faith in the safety of the aircraft im more worried about hijackings surrounding whats going on in Paris
There are too many variables to make a blanket statement like that. I would rather spend an hour in a plane than eight on the ground. Do not forget that planes can glide, so engine malfunction =/= you're dead. Ground communication will  direct the pilots to the nearest airport.
Yes, I know the mere fact of being thousands of feet in the air can still be frightening.
<_<
Especially when the opposite has actually been proven to be the case.
I honestly wouldn't worry about it too much, you should be fine (and Europe probably isn't the place I'd want to be right now anyway....so...)
PSU Tier List | CoC
Gaming Build | FreeNAS Server
<_<
I would rather spend an hour in a plane than eight in on the ground.
im pretty sure the chances of having a car crash is higher you're probably not going to die. Chances of a plane crashing maybe alot lower but if it does crash chances are its fatal
Edit a relative of mine is a air hostess who flies nearly everyday and shes fine although she only flies to Europe and I feel like if anyone was to hijack a plane itd be a plane to New York
There are too many variables to make a blanket statement like that. I would rather spend an hour in a plane than eight in on the ground.
id rather die from my mistake then someone elses.
this/\
yes, but if you take the total statistical odds, then the odds of dying in a car crash are still FAR higher (it's not even remotely close).
Well, my issue with a plane crash would be that it's going to be a terrifying few minutes leading up to it whereas a car crash is more instantaneous. But you're still far safer in a plane.
PSU Tier List | CoC
The odds of the plane crashing are lower than that of driving.
Y'see, I work on the logic of lightning never strikes the same place twice.
If a plane has already been hijacked, the likelihood of another plane getting hijacked soon after is so unlikely that it isn't really worth the energy needed to think about it.
DAYTONA
PROCESSOR - AMD RYZEN 7 3700X
MOTHERBOARD - ASUS PRIME X370-PRO
RAM - 32GB (4x8GB) CORSAIR VENGEANCE LPX DDR4-2400
CPU COOLING - NOCTUA NH-D14
GRAPHICS CARD - EVGA NVIDIA GEFORCE GTX 980Ti SC+ ACX 2.0 w/ BACKPLATE
BOOT and PROGRAMS - CORSAIR MP600 1TB
GAMES and FILES - TOSHIBA 2TB
INTERNAL BACKUP - WESTERN DIGITAL GREEN 4TB
POWER SUPPLY - CORSAIR RM850i
CASE - CORSAIR OBSIDIAN 750D
the car crash probbly won't kill me
the plane crash will.
Do the mods have a new badge something looks different
You're still far more likely to die in a car crash since car crashes are far more common.
PSU Tier List | CoC
Tell that to all the people who have died from a car crash. If you crash in both, your chances of dying have increased significantly. The chances of a plane crashing are lower than that of a car crash.
Edited by Godlygamer23
The "staff" icon was changed a little while ago.
Its not fatal.
Your fucking dead if your not near a airport
Insert   Dank   Signature   Here.
the plane crash wil
The odds are what's important, not the outcome.
Yeah, not being able to do anything about it is the worst part. Its inevitable the only way id imagine surviving is waiting for the plane to drop to a low enough altitude so it wont kill you and then try and jump out the plane but I think that only works in theory
actually you are more likely to die in a car crash planes are quite safe i have flown them since i was 11 (21 now) never had any problems i have driven since i was about 15ish and have had two bad accidents (one was my fault one wasn't). anyways to the op you are actually safer flying after a recent terrorist attack and hijacking because they tighten security.
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
Its not fatal.
*being inside the plane while it crashes
There is one great thing im excited about, Im landing in NYC on the 27th. Thats black friday really wanna pick up a 4790k
