intel CPU: 80-90C is what you should try to not surpass
amd CPU: usually 62C, some can do 65-70
nvidia GPU: less than 85C
amd GPU: less than 95C
https://linustechtips.com/topic/481063-how-hot/#findComment-6453257
I like how AMD GPUs can run hotter than their competition, but their CPUs have to run much lower than competition.
https://linustechtips.com/topic/481063-how-hot/#findComment-6453265
AMD CPU division and AMD GPU division are very different
their GPUs are keeping up with latest technology, have very competitive performance, and actually rival a much larger company (nvidia)
their CPUs however are just pretty much failures that are 5+ year old technology
https://linustechtips.com/topic/481063-how-hot/#findComment-6453283
Rest of forum, PLEASE do not start a flame war...
https://linustechtips.com/topic/481063-how-hot/#findComment-6453288
I run my case fans at around 700RPM, fast enough to cycle the air effectively, but slow enough to be practically inaudible.
GPU, well the stock config, for the TF5 (your cooler) means the fans don't spin until the GPU hits a certain temp, (probably around 50-60°C). Hitting 85 is not much of an issue, it's over 90 where the card should start throttling.
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/481063-how-hot/#findComment-6453497
