So, on speedtest.net my mac gets 30mbps down, while my PC only gets 10mbps down.
They are about 5 feet apart on my desk, so I'm wondering what it is that could be causing this, and is there anything I can get to increase my wifi?
Edit: I also noticed that posititioning of my PC makes a big difference. Can I get extender cables for my wifi adapter? I have three antennae
https://linustechtips.com/topic/479611-increasing-wifi/
the wireless adapter
plus maybe a few settings in the wireless cards drivers
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6432996
use an ethernet cable instead of wifi
you will get better speeds on both
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6433014
Can't, at a cost perspective it's not worth it.
But I also noticed that posititioning of my PC makes a big difference. Can I get extender cables for my wifi adapter? I have three antennae
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6433026
If its a mac laptop, I know from experience that those cards have outstanding range (Mine being able to reach through 3 floors and a metal beam and still playing video. So I would look into the wireless card in the PC. Any idea what it is?
*EDIT* just saw it in the sig.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6433027
Check my signature for my full rig.
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6433042
i7 4790k | GTX 970 | 16GB
That's all you need to know. It's a beast.
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6433043
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6433048
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6433058
Currently not looking for a large antennae, but a cable so I can place my antennae so they face the router without having to turn my pc so all I see is the back IO
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6433074
update your drivers to
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6433084
How do those even work? Isn't it essentially just a wireless to wired adapter?
It uses the electrical wiring in your home to transfer data like an ethernet cable. I use them, and they work great. You place one in the wall and plug it into your router with ethernet, and place the second one near whatever you want to plug in, and connect it with ethernet.
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6433101
they use the power cables in your house to connect the internet...instead of ethernet
no need to lay cable
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6433103
Moving the antennae you have now won't make that much of a difference since they are omnidirectional, meaning that they send/receive frequency in all direction no matter which way they face. Moving them closer to the router with a cable would work, but then you'd have a cable with antennae dangling off it somewhere.
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6433109
So would I have to connect my router to my power system..?
I'd use it I just don't know how I could set it up.
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6433121
I was able to get an extra 5 mbps when I moved them.
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6433124
Moving it closer works, but orientation doesn't matter. You said you wanted to point them at your router, so I was just making sure you knew that wouldn't matter. You could buy an extension and move the antennae closer, but you would have to deal with even more cables.
This is kind of how it goes:
Powerline adapter 1: You plug it into the power outlet on a wall near your router. You then connect an ethernet cable from the powerline adapter to your router.
Powerline adapter 2: You plug it into a power outlet near your PC. You then connect an ethernet cable from the powerline adapter to your PC.
After that, it will work like a wired connection.
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6433146
So let me get this straight..
I plug the first box into any power outlet near the router, and connect ethernet to that.
And then I plug the second box into any power outlet near my pc, and then plug my pc ethernet into that.
Also, would it work if I used this with a power strip?
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6433186
That is correct. And it acts like an ethernet cable would.
And
A lot of people say not to plug it into a power strip because the circuits in it could degrade or damage the quality of the powerline signal, but I have used mine on power strips before with no problems, so I would get more opinions from people on the forum.
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6433213
yep
and yes to the powerbar...IF it doesn't do any power filtering
should also mention
powerline adapters only work well on good modern copper wiring
only real way to test tho it to buy them and test out the signal
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6433214
You need either a SMA or SMA-RP extension cable, this chart will help you figure out which you have. Note how the center pin is different. SMA-RP is the most common on routers from my experience.
Example cable: http://www.amazon.com/TP-LINK-TL-ANT24EC3S-Antenna-Extension-connector/dp/B0054TY8GY/ref=sr_1_3?ie=UTF8&qid=1446752028&sr=8-3&keywords=sma-rp+extension
https://linustechtips.com/topic/479611-increasing-wifi/#findComment-6433486
