for ($i = 1; $i <= 187; $i++) {    $var = $_POST['choix'.$i];}
I don't know if this is what you imagined but at least you have your loop...
$POST sounds like OP is trying to use a form of some sort to post data, though w/o more information hard to really help
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/479414-foreach-post/#findComment-6433797
Have any context for this request? Might make it easier to give you a solution (or suggest a better solution).
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/479414-foreach-post/#findComment-6434964
