Need Urgent Help. Thermal Paste spill over to tiny pins on the side of CPU
Solved by Needfuldoer,
That's not a problem at all. It's not going to do any harm.
If it bothers you that much, use a cotton swab (with the end molded into a better point) to clean it off.
Forvirrad ·
Posted in New Builds and Planning3 -
MiszS ·
Posted in Troubleshooting4 -
1
1
1
Liberty610 ·
Posted in CPUs, Motherboards, and Memory4 -
1
ronaldowrld ·
Posted in Troubleshooting2 -
GC180 ·
Posted in Troubleshooting5
play_circle_filled
Latest From Linus Tech Tips:
AMD Is Copying The Worst Thing About Intel - WAN Show May 31, 2024
