yes, this should be possible. you would need atleast decent internet for this to work smoothly tough.
https://linustechtips.com/topic/475270-hd-streaming-using-a-nas/#findComment-6368945
It has nothing to do with your internet. It has to do with your intranet. Which is much much faster in every situation.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/475270-hd-streaming-using-a-nas/#findComment-6368954
If I were to set up a generic NAS (Network attached Storage) device; would I be able to stream media files such as HD movies to a television, computer or smart phone on the same network? Does anyone else use a NAS for a similar purpose to the intention of mine? Cheers. :D
Plex. Nuff said.
i7 4790k | GTX 970 | 16GB
That's all you need to know. It's a beast.
https://linustechtips.com/topic/475270-hd-streaming-using-a-nas/#findComment-6368960
Yes its possible and I have done it but.... It depends on many factors including but not limited to  a) the read speeds of your hard drives, the bandwidth of you network c) the software setup you use d) the bitrate of you hd video content.
Main Rig: http://linustechtips.com/main/topic/58641-the-i7-950s-gots-to-go-updated-104/ | CPU: Intel i7-4930K | GPU: 2x EVGA Geforce GTX Titan SC SLI| MB: EVGA X79 Dark | RAM: 16GB HyperX Beast 2400mhz | SSD: Samsung 840 Pro 256gb | HDD: 2x Western Digital Raptors 74gb | EX-H34B Hot Swap Rack | Case: Lian Li PC-D600 | Cooling: H100i | Power Supply: Corsair HX1050 |
Pfsense Build (Repurposed for plex) https://linustechtips.com/main/topic/715459-pfsense-build/
https://linustechtips.com/topic/475270-hd-streaming-using-a-nas/#findComment-6368967
welp, this is awkward.
https://linustechtips.com/topic/475270-hd-streaming-using-a-nas/#findComment-6368968
Okay; so assuming I set up a generic NAS - My bandwidth is hefty so that's not a problem. Let's say I have Videos with a ~4000kbps  bitrate and just standard read speeds for my HDDs, nothing special maybe a couple of WD HDDs. Would this be sufficient to stream media effectively?
https://linustechtips.com/topic/475270-hd-streaming-using-a-nas/#findComment-6368999
It would be best if you provided details about your hardware in said "generic NAS"
https://linustechtips.com/topic/475270-hd-streaming-using-a-nas/#findComment-6369053
This is scenario based, I don't actually have any hardware yet because I have not purchased any - Hence why i'm asking about it on forum... I thought that was blatant. Either way, the reason I'm asking is so that I get the correct advice as to whether I need specific hardware etc. or whether a generic, bog standard NAS will do what I want it to do.
https://linustechtips.com/topic/475270-hd-streaming-using-a-nas/#findComment-6369083
You could easily put together NAS that streams media. A lot of software that people use to run a NAS has plug-ins available for specifically that purpose (i.e. Plex). However, when it comes to what content you want to stream and to how many people then hardware will come into play. Most low end NAS can stream a movie with no issues. When you start streaming multiple movies though it may become hard for lower end hardware to keep up. I'm assuming here but I'm sure it would also come into play depending on the resolution you want to stream at as well. As I said though, after a quick search of the web, it seem that even most low-end NAS can keep up with streaming a 1080p movie.
https://linustechtips.com/topic/475270-hd-streaming-using-a-nas/#findComment-6369184
Yea... consider that a 1080p blu-ray streaming requires like 30 MB/s max and modern hdds are around 6x that, provided you don't have an absolutely terrible wireless router, (wired won't have any issues at all), it is almost impossible for a nas system not to be capable of doing it.
https://linustechtips.com/topic/475270-hd-streaming-using-a-nas/#findComment-6369238
~snip~
Hey there Isometric,
Generally it depends on the specific NAS, but most of them can stream media. Regarding the capabilities of it, it's more up to the internal connection rather than the capabilities of the NAS and the drives.
I can suggest checking out what WD can offer as pre-built NAS devices as they are very easy to set up and manage, offer streaming options as well as backups and other useful tools and feature WD Red drives: http://products.wdc.com/support/kb.ashx?id=5BxIfi
Feel free to ask if you happen to have questions :)
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/475270-hd-streaming-using-a-nas/#findComment-6374990
