Hey guys, I'm wondering if water cooling would be feasable in a case that doesnt natively support RADs, can I just stick a 2-fan RAD in push/pull config in place of my current fans? My case is unbranded but it's from somewhere around the 2006 era
I'm not planning to watercool now, but in time when I have the money, and a more powerful processor
My procrastination is the bane of my existence.
I make games and stuff in my spare time.
https://linustechtips.com/topic/475075-watercooling-in-old-case/
if you've got the money to water cool, you've got the money to buy a better case.
might i suggest the 900D?
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/475075-watercooling-in-old-case/#findComment-6365942
You might be able to jerry rig a rad somewhere or if you have the facilities you should be able to cut holes for the rad to go in pretty easily.
However if you're going to be spending a good amount on your computer it's a good thing to also have a decent case.
Sig under construction.
https://linustechtips.com/topic/475075-watercooling-in-old-case/#findComment-6365947
if the fans are placed next to eachother then yes, you should be able to just stick a rad on there. you might find other problems with clearance lateron tough.
generally, all these kind of projects require atleast some form of case modding. so you should consider if you are willing to start cutting things out/adding things to your case.
https://linustechtips.com/topic/475075-watercooling-in-old-case/#findComment-6365955
Do it, why not, but I would suggest buying a Fractal Design Define S.
post-122562-0-67717000-1442090702_thumb.
post-122562-0-87048800-1445205408_thumb.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/475075-watercooling-in-old-case/#findComment-6365964
Well seeing as this is for a project where i'm attempting to push an old case to it's limits; buying a new case defeats the purpose.
Well seeing as my fan mounts are about as close as they can get I should be abe to mount a RAD with some modding then? What if only mounted a thick rad over one fan mount?
Buying a new case would defeat the purpose of this project. :P
https://linustechtips.com/topic/475075-watercooling-in-old-case/#findComment-6366005
It would be nice if you could post pictures.
Off the top of my head you will need to do some major rednecking but it's possible.
If you want to and have the money for it, then yeah, do it.
here you go! mounting a rad in front is basically impossible without mutilating the hard drive mounts.
post-266506-0-86397500-1446039536_thumb.
https://linustechtips.com/topic/475075-watercooling-in-old-case/#findComment-6366018
You'll have to get friendly with a Dremel or tin snips! I installed a120 and a240 in my case that does not support rads (but does have tons of fan slots) and it was a huge pain. I just bought a new case and its coming this week. I don't want that ghetto stuff anymore
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/475075-watercooling-in-old-case/#findComment-6366173
I might have to :P although I have two ports with their covers on, could I mount a rad on the outside? by feeding it through those?
https://linustechtips.com/topic/475075-watercooling-in-old-case/#findComment-6366498
I don't think there's an AIO watercooler with tubes that long. If you're going that direction, you may want to get an expandable AIO and replace the original tubes with much, much longer ones.
I guess you could remove the top fan and cut out the grille to route the tubing.
Adults are just kids with bigger wallets.
https://linustechtips.com/topic/475075-watercooling-in-old-case/#findComment-6366542
Might I suggest doing something like this: http://hardforum.com/showthread.php?t=915156
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
https://linustechtips.com/topic/475075-watercooling-in-old-case/#findComment-6370509
I dremelled out some mesh from my node 804 to run external water-cooling.  Rad + fans + pump + res sit on top of the case.  It's great cause with no real space constriction of internal mounting you can recycle old / used parts.  See link in sig for pics.
TLDR: break out the death wheel!
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
https://linustechtips.com/topic/475075-watercooling-in-old-case/#findComment-6370543
Hmm, interesting. I may just shove some tubing through some empty io panels that have their covers on them, what diameter tubing do you recommend?
maybe i might see about getting a custom fish tank and stick some UV reactive fish in it (Like a double-walled tank, and filling the space between walls with transparent UV reactive fluid. and then sticking some lights in ther and have a pretty sweet looking setup.
Anyone interested in seeing a fish-tank hooked up to a gaming rig?
https://linustechtips.com/topic/475075-watercooling-in-old-case/#findComment-6378924
I run 1/2" ID x 3/4" OD tubing, but really you could get away with 3/8"x1/2" or whatever depending on what barbs you want to buy.  I didn't find that I needed any special angle fittings except from my res to my pump just because of how close together they were and 3/4" tubing not being that flexible.    You're only going to need maybe 4-6 feet total of tubing to round-trip outside the case and back.  Be careful with live fish...if your rad fans fail or something you'll cook them.  I like the idea though.
https://linustechtips.com/topic/475075-watercooling-in-old-case/#findComment-6380767
Yeah, it certainly is an interesting idea I had. And thanks for pointing that out, I'll be sure to find a way to effectively monitor the reservoir temps. Do you know of any colors that go really well with black and gray? I was thinking a luminescent green or blue or something like that.
https://linustechtips.com/topic/475075-watercooling-in-old-case/#findComment-6383771
Black and gray -> orange or yellow.  Pretty much any bright color will work though.
https://linustechtips.com/topic/475075-watercooling-in-old-case/#findComment-6383912
