Amd fx 8350 vs Intel core i7-5960x? Whats the difference?
Why such the huge price difference?? Is it Quality?
Making a production build. 2k-3.5k Everything helps :)
well the main difference between the 2 is that the 8350 has 8 cores and 8 threads while the 5960x has 8 cores and 16 threads. this means the 5960x has 16 virtual cores which makes it way more powerfull. there are a whole lot of more differences but this is the most important one.
the 8350 can be used to replace an i5 in a production build. but cant really be used for gaming because the performance per core is lower.
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
5960X is still the top dog. For most people especially if they do a balanced diet of gaming and work it will fit the bill. OC'd to 5Ghz and able to render 16 threads it makes an excellent workstation and smokes everything else in gaming. For someone strictly doing rendering then comparable 8 core and up Xeons would be other suitable candidates.
I am still eagerly awaiting to see how much life DirectX12 brings to old systems once developers make use of the multi-core performance, hopefully it will be a shot of adrenaline in the jugular for older multi-core systems. This is relative mostly to gaming but throwing it out there because it is still somewhat relevant to the convo.
if you don't know the difference between an FX-8350 and an i7-5960X you clearly need to do more research, and more than likely a 6 cores 12 threads CPU such as the core i7-5820K and an X99 motherboard will be more than enough for you ;)
i guess you could start by compairing some chips on this site, it's fairly accurate and detailed, and it's user submitted so no bullshit:
http://cpu.userbenchmark.com/Compare/Intel-Core-i7-5960X-vs-AMD-FX-8350/2580vs1489
The i7-5960X is really downclocked at factory settings of only 3.0ghz where most of them can do 4.2ghz on all cores easily, so keep that in mind when checking results but there is also an ''overclocked results'' category.
basicaly the most relevant infos for you are right here:
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
Can't be used for gaming why? Why am I able to game above 60FPS using my 8350 if it simply cannot be used for gaming?
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
you can use it but it does bottleneck higher end cards especially in older games. anything below a 290/970 will make no difference but an i5 costs around the same
Stock maybe, not when you've overclocked it... unless you're cramming a 980ti or a titan in with a 8350 then yeah a bottleneck will be there but it will still game with competence so I fail to see how your misinformation forms a fact? I'm running a 970 on my rig overclocked with an overclocked 8350 so I have a bit of an issue with what you're claiming.
A bottleneck and not being able to game are 2 separate things.
Chernobyl
Kraken
snip!
snip!
sni-p!
please stay relevant to the topic, for ONCE this is not about GAMING!!
Here goes the build, this would by my US workstation if i would need to build one from scratch, everything in there is there for a good reason:
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($369.99 @ SuperBiiz)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler  ($104.99 @ Amazon)
Motherboard: MSI X99A Raider ATX LGA2011-3 Motherboard  ($212.98 @ Newegg)
Memory: Corsair Vengeance LPX 32GB (4 x 8GB) DDR4-2400 Memory  ($185.99 @ Amazon)
Storage: A-Data Premier Pro SP600 256GB 2.5" Solid State Drive  ($69.99 @ Newegg)
Storage: A-Data Premier SP610 512GB 2.5" Solid State Drive  ($179.99 @ Amazon)
Storage: Western Digital Blue 3TB 3.5" 5400RPM Internal Hard Drive  ($88.20 @ SuperBiiz)
Video Card: EVGA GeForce GTX Titan X 12GB Superclocked Video Card  ($1029.33 @ B&H)
Case: Phanteks Enthoo Luxe ATX Full Tower Case  ($142.99 @ NCIX US)
Power Supply: XFX XTR 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($96.99 @ SuperBiiz)
Optical Drive: LG WH14NS40 Blu-Ray/DVD/CD Writer  ($44.10 @ SuperBiiz)
Total: $2595.53
Generated by PCPartPicker 2015-10-28 09:47 EDT-0400
If your applications can leverage more from OpenCL and you don't need a ton of video memory, you might want to substitute the cuda (titanX) card for this one instead:
http://pcpartpicker.com/part/sapphire-video-card-212460040g
Total: $2595.53
i would go with an asus x99-a or deluxe and a hitachi or seagate hdd instead but the other parts are good choices
Its one of the OP's choices and he's being misdirected by misinformation, it is relevant.
Chernobyl
Kraken
it's alright, the FX won't make any sense anyways even in a workstation...something like a xeon E3-1231V3 which is an hyper-threaded haswell based quad-core CPU running at 3.8ghz boost will slap bitch the AMD FX in every kind of workloads you can think of and it will end-up being the same price once you factor in a proper overclocking motherboard and CPU cooling for the long outdated AMD chip.
Pretty true, made sense when I bought mine back in the day but Zen is a year away now so never know. Agree on the Xeon.
Chernobyl
Kraken
Honestly, I'd recommend the 5820k for production. you're going to save a TOOOON of money and the real-world performance difference isn't that big to justify spending $1000 on a chip. Put the extra money into your graphics card.
If what I'm posting has already been posted, I'm sorry.
Back then, when the FX launched it was competing with the i5-2500K in terms of it's pricing but offered better multi-threaded performance when compaired to anything intel had similarly priced at this point...worse single-thread performance across the board though but still for SOME scenarios it performed better than intel at similar cost...so it did made sense at some point for some people to go with the AMD FX, but nowadays it's very long in the tooth and it's just a wrong choice for pretty much everyone unless maybe you can get an AM3+ board for VERY cheap (bundled with the CPU...motherboard for free...something like that you know) and your budget is like ''as low as possible'' kind of thing.
AMD has much smaller cores and the Intel CPU has double the amount of treads! :D
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
i think you meant ''AMD has much SLOWER cores and the Intel CPU has double the amount of treads! '' which would be more accurate since in terms of size the AM3+ CPU's and socket 2011 are pretty comparable in size :) but not in speed...
i think you meant ''AMD has much SLOWER cores and the Intel CPU has double the amount of treads! '' which would be more accurate since in terms of size the AM3+ CPU's and socket 2011 are pretty comparable in size :) but not in speed and power consumption...
Actually they are smaller to also the X99 chips is at 140W TDP was they not? :D
yeah lol i corrected the post i've checked some figures for an overclocked 5960X and when you stress all the FPUs on that thing it can pull some serious power...similar to an overclocked FX-8 indeed! :P
Well it sure has more performance per wattage! xD
I appreciate the help :)
However I am looking more into audio production that video production. (though I can see myself editing for music videos) I use DAWS and Virtual Instruments, and those programs do take advantage of hyperthreading, Some synths can eat an entire core while other sampled instruments can run a 1-3 gigs of ram each.
