Hi guys, I will be listening to music on Pandora, Spotify, VLC, etc, while exporting a video, and once my CPU hits 100% I start to get audio skips or distortion every once in a while. It doesn't happen every time, but usually for the first few seconds after my CPU hits 100% I get maybe 9-10 skips lasting about 2 seconds each and about 5 seconds in between them. Is this normal, or is there a fix? I am on WIndows 10 if that helps.
Main PC: i5 4590 @ 3.5 GHz ♦ RX 480 Armor OC ♦ 16 GB DDR3 ♦ GA-Z97-HD3 ♦ 120 GB 840 EVO ♦ 120 GB Intel 520 ♦ W10 Home
Scrapyard PC: Xeon X5460 @ 3.8 GHz ♦ HD 7870 ♦ 8 GB DDR2 ♦ GA-P35-DS3L ♦ 80 GB Intel 320 ♦ 160 GB WD Caviar SE ♦ W10 Home
https://linustechtips.com/topic/462122-audio-glitches-when-cpu-maxed-out/
thats normal
your PC media player requires CPU processing with 0 delay for playing audio
but why is your CPU at 100%...
God damn, what CPU do you have? If it's performing so badly that the audio driver is unable to communicate then you need an upgrade.
in his sig
OP: why is it at 100%
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
in his sig
I can think you can tell by your CPU... I think time for an upgrade. Like everyone is saying... WHY IS IT 100%? You trying to kill it?
thats normal
Like I said, while I'm rendering and/or exporting video.
Well normally people don't use their PC while it's rendering...
Haha true, I just like to use it to watch YouTube while I wait for the rendering to finish.
yeah well thats what happens when your CPU is being used all for rendering
other programs dont work properly
you can either limit the rendering to a few of your cores or just not render while listening to music
Use one core to render and leave the other one to do other stuff.
But it is normal to have those issues when you try to do something else while you render something.
The stars died for you to be here today.
A locked bathroom in the right place can make all the difference in the world.
And you're doing this on a dual core CPU? No wonder the audio glitches.
>G3240
>100% CPU Usage
>Go figure.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
Try to lower the priority of the conpute intensive programm (render programm).
By doing so, the cpu should be able to keep the audio data buffer filled.
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
