If we had some idea on what games you would be playing on Ultra that would be nice. Also what fame rate are you looking for 30 or 60.
 (\__/)
(")_(")  GTX 1070 5820K 500GB Samsung EVO SSD 1TB WD Green 16GB of RAM Corsair 540 Air Black EVGA Supernova 750W Gold  Logitech G502 Fiio E10 Wharfedale Diamond 220 Yamaha A-S501 Lian Li Fan Controller NHD-15 KBTalking Keyboard
https://linustechtips.com/topic/457858-need-help-to-build-pc/#findComment-6144128
playing all games at ultra and high FPS might be pretty hard on that budget.
anyway, are you okay with second hand components?
https://linustechtips.com/topic/457858-need-help-to-build-pc/#findComment-6144138
i assume you need an OS
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($165.99 @ SuperBiiz)
Motherboard: Asus H81M-E Micro ATX LGA1150 Motherboard  ($50.99 @ SuperBiiz)
Video Card: MSI Radeon R9 390 8GB Video Card  ($329.98 @ SuperBiiz)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($43.99 @ SuperBiiz)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($26.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($94.89 @ OutletPC)
Case Fan: Cooler Master SickleFlow 69.7 CFM 120mm  Fan  ($3.99 @ Newegg)
Other: Tek Republic TUC-2000 3.5" USB 2.0 CF/SDHC/SDXC/microSD/MicroSDXC/miniSD/MMC/MS/XD All-In-One Internal Card Reader ($8.99)
Total: $810.69
Generated by PCPartPicker 2015-09-28 12:59 EDT-0400
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/457858-need-help-to-build-pc/#findComment-6144139
Total: $810.69
 This build is pretty good. Can't complain about anything. Very good performance also.
 (\__/)
https://linustechtips.com/topic/457858-need-help-to-build-pc/#findComment-6144237
i need a gaming pc as cheap as possible
for playing all games at ultra dont mention the screen the budget is 845 us dollars
This is the wrong section. Also, "cheap as possible" and "all games at ultra" don't work together. You either get one, or the other.
If you are looking for the cheapest possible gaming PC's, then this guide from @Sauron will help: http://linustechtips.com/main/topic/298009-console-alternatives-d-my-edition-updated-sep-23-2015/
If you are looking for a PC to max all games on ultra, you won't do that for $845. Not unless you are fully content with 1080p gaming and going no higher.
Motherboard: Gigabyte GA-B150M-D3H DDR3 Micro ATX LGA1151 Motherboard  ($75.99 @ SuperBiiz)
Video Card: MSI Radeon R9 390X 8GB Video Card  ($399.99 @ Amazon)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($44.99 @ Amazon)
Total: $865.64
Generated by PCPartPicker 2015-09-28 13:09 EDT-0400
$20 over budget, but it will last the longest. Skylake CPU, 390x, 16GB of memory. Should handle whatever you throw at it, as long as you do not expect to play at 4k.
My (incomplete) memory overclocking guide:
Does memory speed impact gaming performance? Click here to find out!
On 1/2/2017 at 9:32 PM, MageTank said:
Sometimes, we all need a little inspiration.
https://linustechtips.com/topic/457858-need-help-to-build-pc/#findComment-6144238
OK then. This build will be faster in pure performance:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.89 @ OutletPC)
Motherboard: ASRock Z97M Pro4 Micro ATX LGA1150 Motherboard  ($91.98 @ Newegg)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory  ($37.99 @ Newegg)
Storage: Hitachi Deskstar 1TB 3.5" 7200RPM Internal Hard Drive  ($39.70 @ Amazon)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($333.98 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($35.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($54.99 @ Newegg)
Total: $849.51
Generated by PCPartPicker 2015-09-28 13:14 EDT-0400
But this will feel faster overall:
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($69.98 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.00 @ Amazon)
Total: $852.51
Generated by PCPartPicker 2015-09-28 13:15 EDT-0400
https://linustechtips.com/topic/457858-need-help-to-build-pc/#findComment-6144268
Total: $865.64
i am ready to spend more but not too much
https://linustechtips.com/topic/457858-need-help-to-build-pc/#findComment-6144362
Total: $849.51
Total: $852.51
https://linustechtips.com/topic/457858-need-help-to-build-pc/#findComment-6144370
In case nobody else has mentioned it, this is not exactly the correct section. Try the "New Builds and Planning" section of the LTT forums: http://linustechtips.com/main/forum/18-new-builds-and-planning/; this portion is supposed to be for tech news
https://linustechtips.com/topic/457858-need-help-to-build-pc/#findComment-6144546
