/me builds gaming PC for significant other so you can play together
/me has no money to buy him/her games
-or-
/me goes to work
/me uses 17" 4:3 monitor
/me doesn't have dual 24" 16:9
/me brings in 16:9 so I can have dual
/me notices mouse isn't ergonomic and keyboard isn't mechanical
/me brings those in too
(yes, this happens)
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
https://linustechtips.com/topic/453374-pcmr-problems/page/3/#findComment-6083920
-or-
/me goes to work
/you finds some other problem
/you gives up and brings entire setup to work
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/453374-pcmr-problems/page/3/#findComment-6083947
Was actually told I wouldn't once. So I did.
https://linustechtips.com/topic/453374-pcmr-problems/page/3/#findComment-6083954
-or-
/me goes to work
(yes, this happens)
This was me at my last job. I was like "typing... can I bring in my own keyboard" and my employer was like "hell yeah."
and data entry is so much easier when you have one of logitech's scroll wheels.
This was me in school when all the computers were slow AF so I just brought in my SSD-driven laptop. Fastest computer in the school.
https://linustechtips.com/topic/453374-pcmr-problems/page/3/#findComment-6084019
Yup. Try typing in a notes for a work order on a TKL membrane point-of-sale keyboard. Can't find an image, but yeah. No.
EDIT: No mouse natively either, just touchscreen POS or trackpad on the keyboard.
https://linustechtips.com/topic/453374-pcmr-problems/page/3/#findComment-6084044
Physical copies are a worth a lot less
https://linustechtips.com/topic/453374-pcmr-problems/page/3/#findComment-6085138
Cmon now.... Don't be that guy...
"Ahhh, Just Ignore Him, He'll GO away!"
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/453374-pcmr-problems/page/3/#findComment-6085160
  1. The pain the ass of having to reinstall Windows when buying a new boot SSD
Desktop icons being rearranged after streaming to shield (or in my case, my phone)
The lack of transportability/desk space requirements with big desktops
Kodi or other software can be buggy if trying to navigate with ONLY controller
Water cooling leaks
Finding out what component won't let the PC boot
Spending hours trying to create perfect fan curves
Spending hours on here and PCPartpicker picking out specs/building PCs
Spending hours learning how to build a PC and what specs work best
Having to spend more money on the tower and peripherals
Gaming laptop kicks out too much heat/is too bulky/battery life is too short
Having a multi-GPU setup micro stutter, games don't work with other GPUs
Driver updates/OS updates or lack thereof fucks up your PC
Finding out your brand new component doesn't fit in the case (especially SFF cases)
Finding out that you have to upgrade additional components when that brand new component doesn't work with the current hardware config
Having something short out or creating sparks
Knocking over the entire PC (earthquakes if you don't believe that kind of an accident can happen)
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/453374-pcmr-problems/page/3/#findComment-6085332
Laughable, PC unworthy Piss Ports. :angry:
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/453374-pcmr-problems/page/3/#findComment-6085680
  2. Desktop icons being rearranged after streaming to shield (or in my case, my phone)
  3. The lack of transportability/desk space requirements with big desktops
  4. Kodi or other software can be buggy if trying to navigate with ONLY controller
  5. Water cooling leaks
  6. Finding out what component won't let the PC boot
  7. Spending hours trying to create perfect fan curves
  8. Spending hours on here and PCPartpicker picking out specs/building PCs
  9. Spending hours learning how to build a PC and what specs work best
  10. Having to spend more money on the tower and peripherals
  11. Gaming laptop kicks out too much heat/is too bulky/battery life is too short
8/11 not bad
- no WC , and no HTPC cuz .. well... your description describes me..
https://linustechtips.com/topic/453374-pcmr-problems/page/3/#findComment-6085700
Weird screen res combo (main display is 1650x1050 and secondary is 1280x1024). Because I use spanned wallpapers, they need to be at least 8k for them not to look like utter shit.
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/453374-pcmr-problems/page/3/#findComment-6085702
As a previous console gamer I see g2a as my answer to second hand games. :)
there are some seriously cheap games on that site sometimes, like wow
Silverstone ML08  ||  Intel i5-6600  ||  Gigabyte HD 7950 @ Stock  ||  Corsair 2x4GB DDR4 2133MHz  ||  Gigabyte H170-N WIFI  ||  Samsung 840 Pro 128GB  ||  WD Caviar Black 1TB  ||  MSX 64-bit
https://linustechtips.com/topic/453374-pcmr-problems/page/3/#findComment-6086299
i know this feel as someone with a 2560x1080 main panel and 1920x1080 secondary. hey, i love your rig btw! can you not push your fx any more than 4.2ghz? also, what's the core clock on that 270x at?
https://linustechtips.com/topic/453374-pcmr-problems/page/3/#findComment-6086310
dude just clone your boot ssd
https://linustechtips.com/topic/453374-pcmr-problems/page/3/#findComment-6086314
I managed to get it stable at 4.8GHz but I gave up on tweaking it. Went back to stock clocks since I don't trust my current TIM and I want to get an extra fan on the rad. The wiki page is severely outdated. I should probably fix that but I got hooked on D3 again so no chance of that real soon :P
My last firestrike bench was at 1080MHz and I can bump it up to 1120 in Gaming mode, but that gave me a bit of a headache after upgrading to Win10
I'm probably going to get back onto overclocking the CPU and the GPU once November hits (or slightly chillier weather. Room temp skyrockets - I was sitting at 36C on Sunday morning and had to turn the AC on at 16C just so I could get to a more tolerable 24-26C -, since the PC is on pretty much 24/7 and I can't have the AC on all the time since I don't live alone and it's not in my room)
CPU-Z of my highest stable OC :D
Sheet on highest I've ever managed to get. Kept stable for about 12 hours during bench, then it crashed forcing me to go back to stock: http://valid.x86.fr/ityw79
https://linustechtips.com/topic/453374-pcmr-problems/page/3/#findComment-6086353
