I have to ask a silly question, do you even Steam Bro?
I don't get what you are asking. I buy my games from g2a and activate them on steam.
I7 4790K-----ASUS Z97-A-----GTX 1080-----CORSAIR H105-----CORSAIR VENGEANCE PRO 16GB-----ASUS PG278Q-----LOGITECH G900-----MASTERKEYS PRO L-----Sennheiser GSX 1000
https://linustechtips.com/topic/453374-pcmr-problems/page/4/#findComment-6086363
I managed to get it stable at 4.8GHz but I gave up on tweaking it. Went back to stock clocks since I don't trust my current TIM and I want to get an extra fan on the rad. The wiki page is severely outdated. I should probably fix that but I got hooked on D3 again so no chance of that real soon :P
My last firestrike bench was at 1080MHz and I can bump it up to 1120 in Gaming mode, but that gave me a bit of a headache after upgrading to Win10
I'm probably going to get back onto overclocking the CPU and the GPU once November hits (or slightly chillier weather. Room temp skyrockets - I was sitting at 36C on Sunday morning and had to turn the AC on at 16C just so I could get to a more tolerable 24-26C -, since the PC is on pretty much 24/7 and I can't have the AC on all the time since I don't live alone and it's not in my room)
CPU-Z of my highest stable OC :D
Sheet on highest I've ever managed to get. Kept stable for about 12 hours during bench, then it crashed forcing me to go back to stock: http://valid.x86.fr/ityw79
why not just bump it back down a little bit to like 4.4ghz or something? why all the way back to stock? i get you with MSX though, can be a pain sometimes (not to even mention the privacy concerns). it is okay though, and it will get a lot better with time i imagine
Silverstone ML08  ||  Intel i5-6600  ||  Gigabyte HD 7950 @ Stock  ||  Corsair 2x4GB DDR4 2133MHz  ||  Gigabyte H170-N WIFI  ||  Samsung 840 Pro 128GB  ||  WD Caviar Black 1TB  ||  MSX 64-bit
https://linustechtips.com/topic/453374-pcmr-problems/page/4/#findComment-6086572
It was pretty late on a workday and I couldn't be bothered to do anymore tweaking. Had alot of work-related things to take care of then I got sick and didn't really have the time or energy to bump it back up. Even at stock (with a 4GHz boost clock) I don't have issues or bottlenecks in games, as far as I can tell (1680x1050+1280x1024 display setup, only playing on main monitor)
The temp issues are kind of holding me back from overclocking again. I'd want to get a couple of SP fans on the rad before I try again (currently only have a single 120mm AF cooler on the rad which struggles to keep the temp when it gets out of hand.) Ideally aiming for a max of 40C maxtemp under load, but that will take some time since I also have to tinker with the fan curves and the fact that my mobo only has 2 PWM headers makes it tricky.
I'm considering buying a fan controller but I'm unsure of the benefit of one
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/453374-pcmr-problems/page/4/#findComment-6086639
I've got a bunch... :D
-Getting crossfire setup for the first time and getting it to work properly (silly AMD Overdrive and Powertune).
-Getting used to using multiple monitors and feeling claustrophobic when forced to use a PC with only one.
-When using water to cool the GPUs in your system is a necessity
-When your PC runs so quiet, you have to put your ear right up to it to confirm it's still running.
-When you're playing a game and you have to alt-tab out to change the podcast you're watching/listening to.
-When you get distracted looking in the side panel window of your PC and get killed in the game you were playing (true story lol).
-When you have so many windows/tabs/programs open at once and you forget what the heck you were doing.
-When you spend more time tweaking the graphics settings than you do playing the actual game.
-When you spend hours tweaking and testing your system fan curves/settings.
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
https://linustechtips.com/topic/453374-pcmr-problems/page/4/#findComment-6087096
When a console peasent (Your cousin) comes to your house and says, I brought some games and a potatobox.
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
https://linustechtips.com/topic/453374-pcmr-problems/page/4/#findComment-6087754
Weird screen res combo (main display is 1650x1050 and secondary is 1280x1024). Because I use spanned wallpapers, they need to be at least 8k for them not to look like utter shit.
Same, I have a primary 1080p monitor and a secondary 1600 by 900p monitor
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/453374-pcmr-problems/page/4/#findComment-6092375
dude just clone your boot ssd
That doesn't work for me. Alienware didn't partition my 1TB boot HDD, so I can't clone anything onto my SSD without getting deleting my entire library of games. Only way to install Windows is to get a new Win 7 CD (Which completely fucked up), or upgrade to 10 on the HDD and then create a new USB stick and put that on the SSD
https://linustechtips.com/topic/453374-pcmr-problems/page/4/#findComment-6092389
Everything.
Blue Jay
CPU: Intel Core i7 6700k (OC'd 4.4GHz) Cooler: CM Hyper 212 Evo Mobo: MSI Z170A Gaming Pro Carbon GPU: EVGA GTX 950 SSC RAM: Crucial Ballistix Sport 8GB (1x8GB) SSD: Samsung 850 EVO 250 GB HDD: Seagate Barracuda 1TB Case: NZXT S340 Black/Blue PSU: Corsair CX430M
Other Stuff
Monitor: Acer H236HL BID Mouse: Logitech G502 Proteus Spectrum Keyboard: I don't even know Mouse Pad: SteelSeries QcK Headset: Turtle Beach X12
GitHub
https://linustechtips.com/topic/453374-pcmr-problems/page/4/#findComment-6092458
i7 does 4.8ghz... would do more if i could custom loop... not ever happening.
REDLINECore i7 6700k 4.8ghz 1.37v.Noctua NH-u12s.MSI Z170A Gaming M7.16GB Kingston Hyper X Fury Black.MSI Gaming R9 390 8GB Crossfire + GTX 780 PhysX.Samsung EVO 850 500GB SSD.Fractal Design Define R5 Midi Black.SeaSonic X Series 1050w Gold.Logitech G302 Deadalus Prime.Ducky DK2108 Zero Mech Cherry Blue.
https://linustechtips.com/topic/453374-pcmr-problems/page/4/#findComment-6094404
