I am about to purchase the parts for my grandmothers computer and I was wondering if could get some approval. I am not really looking to change anything (unless you know of a better component for cheaper or equal price) and I am mostly seeking approval. Just kind of want people other than me to check for mistakes. Thank you in advance for the help.  :)
Here is the PCPartPicker List: http://pcpartpicker.com/p/GJ4Zbv
https://linustechtips.com/topic/452632-building-a-computer-for-grandma/
Here is the PCPartPicker List: http://pcpartpicker.com/p/P2wmMp
Motherboard: Gigabyte GA-B85M-DS3H Micro ATX LGA1150 Motherboard  ($62.89 @ OutletPC)
Storage: Kingston HyperX Fury 120GB 2.5" Solid State Drive  ($56.90 @ Mac Mall)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($40.00 @ NCIX US)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply  ($24.99 @ NCIX US)
Total: $288.65
Generated by PCPartPicker 2015-09-19 10:48 EDT-0400
you dont need that i5, an i5 4460 will be fine and get a better psu, this is the build doing that PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($179.99 @ NCIX US)
Motherboard: ASRock H97M-ITX/AC Mini ITX LGA1150 Motherboard  ($66.98 @ Newegg)
Case: Cooler Master Elite 130 Mini ITX Tower Case  ($34.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($21.98 @ Newegg)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($89.99 @ NCIX US)
Total: $570.89
Generated by PCPartPicker 2015-09-19 10:47 EDT-0400
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
Total: $288.65
do not get the psu
i dont think your grandma needs an i5 tho.....
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($175.88 @ OutletPC)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory  ($37.99 @ Amazon)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($44.73 @ B&H)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($50.89 @ OutletPC)
Power Supply: XFX TS 550W 80+ Gold Certified ATX Power Supply  ($44.99 @ NCIX US)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($16.59 @ OutletPC)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($86.89 @ OutletPC)
Total: $559.93
Generated by PCPartPicker 2015-09-19 10:49 EDT-0400
The site has changed....
Looks fine, you could save a lot of money buy getting Windows 10 off G2A or Reddit.
The OS I am not really worried about, I already have a copy of windows that I plan on using. That is mostly just there for a place holder, but thanks for the help anyways.
do not get the psu
She's isn't going to OC. 500w+ is pointless and overkill.
doesn't change that that psu is going to die easily and could easily take the system with it, @STRMfrmXMN and @Aniallation will agree with me
Okay thanks because I was kind of worried about the PSU from the begining but the reviews said otherwise. Do you have any suggestions?
the one i put in my build will be just fine
It's got nothing to do with wattage. It's the fact that the EVGA 80+ series is terrible...
Since your grandma runs a business, we don't need if there are any softwares or settings that needs pro such as connecting to a domain. If pro is not needed, then she can go with windows 10 home.
comparison: https://en.wikipedia.org/wiki/Windows_10_editions
Went with a hybrid drive so she has the space of a hdd and the speed of a ssd. Core i3 for 2 cores and 4 threads. I'm guessing she will be doing word processing most of the time, so the extra threads on the core i3, is good enough for her needs.
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor  ($112.89 @ OutletPC)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($68.99 @ NCIX US)
Memory: Kingston HyperX Fury Blue 8GB (2 x 4GB) DDR3-1600 Memory  ($41.99 @ SuperBiiz)
Storage: Seagate  1TB 3.5" 7200RPM Hybrid Internal Hard Drive  ($69.49 @ OutletPC)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($32.99 @ SuperBiiz)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($29.99 @ Newegg)
Optical Drive: Asus DRW-24F1ST DVD/CD Writer  ($12.99 @ Newegg)
Operating System: Microsoft Windows 10 Pro OEM (64-bit)  ($138.79 @ OutletPC)
Total: $508.12
Generated by PCPartPicker 2015-09-19 13:39 EDT-0400
get the xfx from my build, gold rated psu, made by seasonic. Quality and quiet cheap
