It looks good-n-all but i would purchase my parts from amazon.com and elsewhere to get the best prices.
16Gb of White RAM = $85
X61 is better but with these fans
HOF GPUs are great but the company is wonky.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/450353-white-build/#findComment-6037878
If you are looking for a really good AIO I would also look at this one. I'ts made by EKWB and from what I've seen, it can rival a custom loop.
http://predator.ekwb.com/
CPU: i7-8700K I CPU Cooler: Noctua NH-D15 GPU: ROG Strix 1080 Ti MoBo: ROG Strix Z370-E RAM:  G.SKILL Ripjaws V Series 32GB (2 x 16GB)   PSU: CORSAIR HXi Series HX1000i Case: Corsair Air 540 Display: 24" 1920X1080p 144Hz ASUS - 27" 2560X1440p 144Hz Dell OS: Windows 10 Home 64bit
https://linustechtips.com/topic/450353-white-build/#findComment-6037884
no no no
dont get those fans
get corsair sp140 fans quiet edition
"God created war so that Americans would learn geography"
https://linustechtips.com/topic/450353-white-build/#findComment-6037887
aha
you mean this quote where you say the x61 is better with these fans
https://linustechtips.com/topic/450353-white-build/#findComment-6037914
aha
I posted the wrong size, which was a mistake on my part, i will now change it to the correct size and it will still beat the Corsair sp stupid crap.
https://linustechtips.com/topic/450353-white-build/#findComment-6037926
except it wont because you need static pressure fans for a radiator instead of airflow fans
https://linustechtips.com/topic/450353-white-build/#findComment-6037934
So I don't use the fans that come with the X61?
they are fine but spend a bit more money on Corsair SP140 Quiet Edition fans. They will be quieter and be made for radiators.
https://linustechtips.com/topic/450353-white-build/#findComment-6037946
Dude please......the hyperboreas has the highest static pressure of any 140mm whit a decibel of lower than 26....what are you really saying?..... what?
https://linustechtips.com/topic/450353-white-build/#findComment-6037951
the x61 is definitely better if you can fit it in your case
if you want quiet fans, dont get corsair
buy something from bequiet, fractal design, or noctua
it will be more expensive though, just fyi
https://linustechtips.com/topic/450353-white-build/#findComment-6037999
So then which fans do I get for the radiator, Corsair or Hyperboreas?
Get the
Kraken x61. Use the stock fans for now. Dont go jumping ln the silemt bandwagon until you think it is to loud.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/450353-white-build/#findComment-6038000
Or Cougar Vortex, some quality fans for a cheapish price.
https://linustechtips.com/topic/450353-white-build/#findComment-6038006
Yeah, no... SP's are not very good.
EDIT: EXXXTREME NOIZE!
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/450353-white-build/#findComment-6038014
