Best earbuds for 30 dollars or under ?
mitsosvazelos84
Hey guys ,
As the tittle suggests , I want to know what are the best earbuds for 30 dollars or under . I really dont care about the sound signature because right now I use shitty 5$ earbuds . Flat cables don't bother me as well . I have heard a lot of thing about the Xiaomi piston series ... are they any good ?
thank you for the help ,
mitsosvazelos84 :)
Try to look at sony's earbuds, I personally like the amount of choice and variety they have.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
I found these ; Are they any good ?
No, they're over $30 ;)
:P The site was just a refference I can get them for like 20 dollars on amazon . How good are they compared to the psiton 3's or the mx 300 ii's ?
If you are ok with clip ons (might not sound like the best idea at first, but for comfort on a budget they can't be beat) and don't need isolation, I would definitely look into the Koss KSC 75s for only $12 on amazon. Amazing bang for your buck and come with a life time warranty. They sound miles better than anything in its price range.
