hay guys this is my build http://pcpartpicker.com/p/n8mPpg i was wondering what would be a good cpu cooler for it. idc if its liquid or air, but my budget for it is $60 (i cant go over). thanks for the help guys. P.S. before you say it leave my 2 sli gtx 970s alone :P.
https://linustechtips.com/topic/449290-good-cpu-cooling/
Stock cooler is fine for you. You've got a locked CPU.
https://linustechtips.com/topic/449290-good-cpu-cooling/#findComment-6023993
WHY WOULD YOU SL.. jk.
Heard good things about the Hyper 212 EVO.
i5-4690k | GALAX HoF 980Ti | MSI Z97 Gaming 3 | 2xHyperX Fury 8GB @ 2133MHz | 2x240GB Kingston SSD in RAID-0 | 500GB Samsung 850 EVO | NZXT H440 | Corsair H75 | Corsair RM750
Do not go gentle, into that good night.
https://linustechtips.com/topic/449290-good-cpu-cooling/#findComment-6024000
so i dont need to is should be able to last 2 years without it
Your CPU will last at 3-4 years. I've got a i7 920 still running like a champ and it's 7 years old.
https://linustechtips.com/topic/449290-good-cpu-cooling/#findComment-6024034
as long as you keep the dust out intel coolers arent too bad...
so i just saty with my current set up i dont need anything else like an sli cord or extra fan for the case.
all coolers i've seen so far come with decent thermal paste, but its always handy to have a tube on hand. (for when reseating the cooler for example)
https://linustechtips.com/topic/449290-good-cpu-cooling/#findComment-6024036
and also do i need to buy any thermal paste
Unless you get the 212 Evo from Cooler master, then no. It comes with the cooler.
https://linustechtips.com/topic/449290-good-cpu-cooling/#findComment-6024041
Depends on the aftermarket cooler you get, for example the CM 212 Evo comes with a small tube should last you a few reseats if you ever need to perform any. Its always good to have a larger tube of thermal paste just in case. Some may come with pre-applied thermal paste.
Regards Elias N Martinez. | Graphic and motion design are my jobs. 3D modeling is my hobby. I do what I enjoy.  Skype: eliasnmartinez1 (please state that you are coming from LTT)
https://linustechtips.com/topic/449290-good-cpu-cooling/#findComment-6024065
Will the size of a room impact the performance of a space heater? Yes, yes it will. Transfer the heat from the CPU to the case and you'll have less of an improvement than if you transfer that heat outside the case. The 212 will help, but spend a little more and the improvement will be much greater.
If anyone asks you never saw me.
https://linustechtips.com/topic/449290-good-cpu-cooling/#findComment-6024134
