Electrical Issues
By
NewbixCube
in Troubleshooting
in Troubleshooting
Solved by W-L,
-SNIP-
Check the gauge of the wire it should say on the wire itself, something at 10-15 ft, 14-16 AWG is pretty good for what you will need having it in coils is fine just not tangled up or bunched together. The smaller the number the larger the diameter of the conductors inside.
Ishikudeska ·
Xxu ·
Posted in Servers, NAS, and Home Lab0 -
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
play_circle_filled
Latest From ShortCircuit:
