Samsung S6 Edge lock screen clock thing?
Ethn
Hi, I just got my s6 edge and I have been using it for a few weeks, sometimes when I come to get it and the phone is locked there is a clock and notifications on this? what is it and how do I purposely enable / disable it?
That means you have the edge clock enabled, it'll turn on between certain hours (which you choose). If you haven't enabled it, you can turn it out by swiping on the edge with your screen disabled.
