I have a ps4 and want to get a nice display for it. Right now its  sharing a display with my computer. The display its using now is a vg248qe.
I'd like to find something that is a larger display and also 1ms. Should i go with ips or tn? Any suggestions you guys? i guess it wouldnt have to be over 60hz seeing as the ps4 will never go over that anyway. Thanks!
NOTE: Obviously the cheaper the better.
TX10 Build Log: http://linustechtips.com/main/topic/456229-tx10-build-log/
Case: TX10-D   Proccessor: i7-5820k   MotherBoard: Asrockx99 Extreme4   Ram: Crucial Ballistix Sport 16GB (DDR4-2400)   GPU: Asus Strix OC 980ti   Storage: 850pro 500gb, 850pro 500gb, 850pro 256gb, WD black 16tb total, Silicon Power S60 120GB   PSU: Seasonic snow silent 1050   Monitors: Three of Asus VG248QE 144Hz 24.0"
https://linustechtips.com/topic/442796-best-display-for-ps4/
the cheapest 60hz tv you can find
My Rig:  CPU: Core i7 4790K @4.8ghz  Motherboard: Asus Maximus Vii Hero  Ram: 4x4GB Corsair Vengeance Pro 2400mhz (Red)  Cooling: Corsair H105, 2x Corsair SP120 High Preformance Editions, Corsair AF 140 Quiet Edition  PSU: Corsair RM 850  GPU: EVGA GTX 980 SC ACX 2.0  Storage: Samsung 840 EVO 120GB, WD Blue 1TB  Case Corsair 760t (Black)  Keyboard: Razer Blackwidow Chroma  Mouse: Razer Deathadder Chroma  Headset: ATH-M50X Mic: Blue Yeti Blackout
https://linustechtips.com/topic/442796-best-display-for-ps4/#findComment-5934429
CPU:Ryzen 9800X3D GPU: RTX 5080 MB: Asus ROG X870E  RAM: G.Skill Trident Neo 64gb CPU Cooler: ROG Ryujin III
https://linustechtips.com/topic/442796-best-display-for-ps4/#findComment-5934430
Why not get an LED TV?
Because TV's have awful input lag..
Would 27 inch be big enough? how far away are you from your screen?
https://linustechtips.com/topic/442796-best-display-for-ps4/#findComment-5934437
But it's for a console though. I figured OP would also use it for Blurays and video streaming.
https://linustechtips.com/topic/442796-best-display-for-ps4/#findComment-5934439
Clearly you did not read my question
Because of the awful input lag they carry with them.
Thank you for being the only person who read the question. 27inch would be fine.. I'm sitting about two feet from it normally. Just when people come over I have to sit back and the larger display is always nice.
https://linustechtips.com/topic/442796-best-display-for-ps4/#findComment-5934443
I did read your question I was just curious.  <_<
https://linustechtips.com/topic/442796-best-display-for-ps4/#findComment-5934449
I wish :/ have $3k tv that ive used probably twice because of the input lag. I will be using this 99% of the time for gaming
https://linustechtips.com/topic/442796-best-display-for-ps4/#findComment-5934451
Didn't mean that at you. you had a good question :).. Meant it at ANewface
https://linustechtips.com/topic/442796-best-display-for-ps4/#findComment-5934458
I don't know about specific good 27" displays with HDMI.. But if you want 1ms response time, IPS is probably not going to be a thing..
Brands I know are good are Dell (maybe take a look at their Ultrasharp line), maybe BENQ (their XL line features a few 27" gaming monitors, just be careful some are 144Hz), Asus has some nice 27" displays too.
Samsung is decent, but can't think of a line of them which is real good.
https://linustechtips.com/topic/442796-best-display-for-ps4/#findComment-5934465
Ok thanks :)
https://linustechtips.com/topic/442796-best-display-for-ps4/#findComment-5934474
wow funny, I just got done gaming on a super cheap 32 inch tv with zero input lag, and didnt even play with the settings. imagine that.
highly recommend a tv if you want a larger display. could get a 30-40inch tv for the price of a 27inch monitor.
https://linustechtips.com/topic/442796-best-display-for-ps4/#findComment-5934493
For 1ms... you won't find any IPS monitors/TVs, for 1ms you should go with a TN panel. I recommend this one: http://www.amazon.com/VS278Q-P-Ultrafast-27-Inch-LED-Lit-Monitor/dp/B009HNEBLK
Everyday build:
CPU: Intel Core i7 5960x - GPU(s): 2x EVGA GTX 980 Ti Superclocked+ ACX2.0+ (SLI) - Cooler: be quiet! Dark Rock Pro 3 - Motherboard: ASUS Sabertooth X99 - RAM: 32GB Kingston HyperX Fury Black DDR4 4x8GB (2666MHz) - Storage: Intel 750 Series 1.2TB + 4TB WD Black - Case: Corsair 760T White - PSU: SeaSonic 1200W 80+ Platinum Certified - OS: Windows 10 Pro - Wireless Adapter: TP-Link Archer T9E - Monitor: Acer XB270HU bprz - Keyboard: Corsair K70 RGB - Mouse(s): Corsair Gaming M65 RGB + Logitech MX Master - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/WhyK99 https://linustechtips.com/main/topic/474247-r8-my-build/
Weekend build:
CPU: Intel Core i7 5930k - GPU(s): 2x EVGA GTX 980 Ti Classified ACX2.0+ (SLI) - Cooler: NZXT Kraken X61 - Motherboard: ASUS X99-Deluxe - RAM: 32GB Crucial Ballistix Sport LT DDR4 4x8GB (2666MHz) - Storage: Samsung 950 Pro 512GB m.2 & 2TB Samsung 850 Evo - Case: Phanteks Enthoo Evolv - PSU: SeaSonic SnowSilent 1050W 80+ Platinum Certified - OS: Windows 10 Home - Monitor: Dell S2716DG 144hz - Keyboard: Corsair STRAFE RGB - Mouse: Corsair Gaming M65 RGB - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/YYK93C
https://linustechtips.com/topic/442796-best-display-for-ps4/#findComment-5934504
Yeah. CHeaper tv's have less input lag  then expensive tvs usually. If it has a nice panel and does post processing  then it all takes time.
https://linustechtips.com/topic/442796-best-display-for-ps4/#findComment-5934553
um. and with the nicer tvs you can always turn it off.
https://linustechtips.com/topic/442796-best-display-for-ps4/#findComment-5934570
nope. You cant turn off the type of panel it is.. lol. There is a "gaming" mode. But it makes very little difference with mine.
https://linustechtips.com/topic/442796-best-display-for-ps4/#findComment-5934576
I'm sure you probably wont need to read it, but here is a nice article just in case you wanted to: https://pcmonitors.info/articles/monitors-for-console-gaming/
It basically says why all you'll want is a 1920x1080 60Hz IPS monitor if it's just for use on your PS4.
And I say IPS because you don't need a 1ms response time, for console gaming OR for highly competitive PC Gaming, in either cases an IPS display with its 4/5ms quoted g2g will be more than good enough, and not to mention as far as ghosting goes (The negative effect of a bad response time) some cheap 1ms TNs can have just as bad or worse ghosting than a cheap 5ms IPS, the same in reverse. The quoted G2G Response time is pretty much meaningless and just a marketing gimmick.
For the best experience due to colour accuracy and viewing angles go for a cheap IPS 1080p 60Hz display.
i5 4690k | GTX 980Ti G1 Gaming | 16GB RAM | MSI Z97 Gaming 7 | NZXT Kraken X61 | 850 EVO 250GB x2  | 1TB 850 Evo NZXT Noctis 450 | EVGA 750W 80+ Gold
 Ducky Shine 3 TKL (Browns) | LG 34UC87C | Logitech MX Master ATH-M50x's + DT990 Pro's
https://linustechtips.com/topic/442796-best-display-for-ps4/#findComment-5934780
Latency comes 100% from the display controller and signal processing. The panel type has no effect on it.
IMO since a console won't be putting out more than 60Hz, I'd go with a nice 1080p IPS panel. The Dell S2715H would be a good choice if you don't mind a glossy finish.
https://linustechtips.com/topic/442796-best-display-for-ps4/#findComment-5934812
