Starting a new pc project geared towards silent gaming. Project silent linus because I'm building it in a black and orange Be Quiet Base 800. Going to buy parts as I go.
Cpu: 5930K (no need for the 8 core Im only going to be gaming anyway)
Cpu cooler: be quiet cpu cooler or a small AIO
Ram: Corsair ddr3 or 4
GPU: pascal or volta
Mobo: X99 Deluxe
PSU: Be quiet psu TBD
Storage: 250gb ssd, 4TB mass storage 7200rpm or higher
Case: Be Quiet BAse 800 no window
Gif is proof Linus is loud.
MainRig- CPU: 4790k, RAM: 32gb 2400mhz, MOBO: Maximus Formula VII, COOLING: Full EK cooling, GPU: Titan X SLI, PSU: 1200w evga , STORAGE: 250gb SSD, 4TB hybrid CASE: 760T, EXTRAS: Sleeved cables
SecondRig- CPU:4690K, RAM: 16gb 1600mhz, MOBO: Maximus Gene VII, COOLING: H105, GPU: 970ftw, PSU: EVG650W,  STORAGE: 250gb SSD, 3TB, CASE: 540air
Steam: pizzatime6 Plus two other pc rigs and a craptop.
https://linustechtips.com/topic/436712-project-silent-linus/
Do,you have any specific parts picked to make,it silent? Like fans, cooler, certain parts like the PSU or GPU.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5854049
Is Linus usually loud? :0
short people are always loud
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5854054
Well the Silent Base 800 is a good start and I assume he's going to go with some silent video card, some quiet fans and a fanless or something power supply.
Sig under construction.
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5854064
What are the parts that you are going to use in this build?
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5854069
Stock fans will do. Im putting a AIO for the cpu cooler. As for the gpu I'm waitning till pascal or volta. For the cpu Maybe a skylake or a lga 2011v3.
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5854071
watercool it!
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5854076
Yeah hopefully.
@OP Here are some budget friendly orange and black fans. Very similar to noctuas specs wise.
http://pcpartpicker.com/part/cougar-case-fan-cfv12hpb
I can link the 140mm ones if wanted.
@Pizzartime6
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5854083
Which water cooler?
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5854086
that's some SiLinus-ness
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5854091
Which water cooler?
Havent decided Ill be creeping the internet for the quietest one or go with a Be Quiet cpu cooler.
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5854105
A BeQuiet! Dark Rock Pro is nice. Also,look at the fans I linked. Would be great fans to add to the build.
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5854132
Wow they look pretty cool!
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5854159
Yeah they are also VERY quiet. Under 20DBA and heave great airflow. They've got a 140mm version also.
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5854188
Think I'm going to go with a X99 mobo. I only want one that can do 3 way sli. Do you guys have any good suggestions?
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5858337
Update: Cpu is now going to be 5960X
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5867775
So fucking true lol
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5867784
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5874414
I was looking at your storage solution, and I am going to say that most often, the loudest part of your computer will be the HDDs.
It is kinda nice that the HDD is the loudest part (since they don't make that much sound) , but they are really friggin annoying when they are the only thing you hear.
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5874892
You should get two cards.. So you can go sLinus.
I'll show myself out...
Higher frame rate over higher resolution.
CPU-i5 4690k -GPU-MSI 970 sli -Mobo-MSI g45 gaming -Memory-16gb crucial ballistix -PSU- EVGA 80+ gold g2 850w -Case- corsair 200r
Monitors- Acer XB240H, Asus ROG Swift, Dell P2815Q 2160p  -Keyboard- Corsair k70 RGB -Mouse- Corsair M65 -Mouse Pad- Glorious Extended Pad -Headphone- BeyerDynamic DT990 250ohm, Senheiser HD 518, Fiio E10k
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5879212
5930k not the 5960X need to save some money and dont need 8 cores for gaming
https://linustechtips.com/topic/436712-project-silent-linus/#findComment-5893841
