hi I'm building a computer that is using 441 wats of energy I have a gtx 980 ti, a i7 quad core, 2TB hard drive, etc. what would be the best power supply for this. My only preference is that it's under $100 and it last a long time. Thanks for the help
500w From corsair or Thermaltake
potato.
G2's last 10+ years lol (as far as the warranty is concerned). They are pretty much the best gold rated power supplies you can buy. But if you want to cheap out a 750b2 will do you well. I think it has a 5 year warranty.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
What kind of dollars are you using?
... Umm..... You know .... I need the pcpartpicker link again lol ps thanks for all your help you have really helped me through all of this
http://pcpartpicker.com/part/evga-power-supply-220g20750xr
/thread
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://pcpartpicker.com/part/evga-power-supply-220g20750xr
I'm working with $1200 I can buy all of this for that deal on cyber Monday I'm just trying to save as much money as I can
That's a long while from now. I'd suggest planning later. ~2-3 days at most before you buy. Parts and prices change frequently so any parts list you come up with now will likely be obsolete by the time you're ready to buy.
EVGA's 550W GS is plenty but you have a long ways to wait to buy these things so just wait. :)
