CPU Purchase? Please help.
Go to solution Solved by FLUFFYJELLO,
Yeah i'm thinking about not spending over 400 USD so after i sell my current mobo and cpu i'm pretty golden, Thanks for all the help really!
Glad I could help! Good luck with the upgrade.
Just got the Geforce GTX 970 Gigabyte G1 and looking to upgrade my cpu to match it.
Current CPU is the AMD FX 4130 and i was thinking about getting the AMD FX 8350 but then a lot of people on other forums say the i5-4690k but there is such a price difference here i'm not sure if it's worth it?
Any help would be greatly appreciated.
Please let me know if you need more info.
https://linustechtips.com/topic/428646-cpu-purchase-please-help/
it is worth it getting the i5 4690k or even the i5 4460 which will give you much better minimum FPS than the 8350 and will allow you to upgrade to an i7 later. even an i3 would fight an 8350
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5749748
The intel is not only more expensive, but would require a new motherboard so it is really MUCH MUCH more expensive...
When in doubt, re-format.
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5749755
-snip-
For gaming, the FX 8350 is just not very great, which is why people recommend the i5 4690K.
If that is too expensive, you could also go down to an i5 4460, which is still a great gaming CPU with a more 'attractive' price tag. Just keep in mind you have to get a new motherboard for this CPU.
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5749756
the FX chip is cheaper, has 8 cores over the i5's 4 cores.
but the i5 has MUCH better single threaded performance, and runs much cooler than the FX.
i'd say i5 if you can afford the chip, but take in consideration the i5 can run on a stock heatsink if money is tight, but the FX will be a jet engine when running with a stock cooler.
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5749757
@GalaxyRogerz since there is a lot of ignorance in this topic, I will assist you. I own a GTX 970 from MSI paired with a FX-8350 overclocked to 4,5gHz.
I have not noticed any bottlenecks from the CPU in any games I played (AC:Unity, The Witcher 3, Battlefield 4, Dragon Age:Inquisition, Tomb Raider).
It's a great CPU for its value and with the upcoming DirectX12 it will be even better in gaming.
Of course i5-4690k is a BETTER CPU, no doubt about it, but if you wanna game and your budget is tight, get the FX. It's more than enough and it's raw power in benchmarks is very close to  the 4690. I would not get the 4690k since I would go either for the cheaper FX option or gather more money for the i7-4790k simply because my usage of the PC benefits from the 8 cores/threads.
With that in mind: i5 is a better CPU, but the FX gets the job done only slightly worse in most modern games since most of them use AT LEAST 4 of the threads, and many of them use all 8, so 8350 after overclock is definitely enough for the 970:)
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5749944
The problem is that i'm 16 and i'm buying all the parts for myself, i have a decent paying job but I've already spent almost 900USD on other parts, i don't think I would be justified getting the i5 but i would if it didn't need another motherboard so I'm thinking about getting the 8350 and use it until next year, then I'll have enough money for a new motherboard and atleast the 4690k.
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5750239
Or, you could just announce your 4300 + mobo for sale at a low price, and once someone ends up buying, you end up with that extra cash for the i5.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5750956
I might just do that but i don't know what motherboard i would have to get and would the motherboard for the i5 cost about the same?
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5757858
The motherboard for the i5 would actually be significantly cheaper than boards rated to both work with and overclock the 8350; which you will need to overclock it to match (kinda) the stock performance of an i5; then get an aftermarket cooler if you don't already have one. Also if you don't have a good enough mobo you'll have to buy a new one anyway to support the power draw of the 8350.
There are many "hidden costs" when going with the *upper tier FX CPUs that Intel just doesn't have. You can overclock an i5 to 4GHz on the stock cooler (it will be loud but you can do it). Some things to consider.
Honestly, if you can hold out on your current CPU until you can go Intel, that's your best option I think. "Upgrading" through the FX line nets almost no performance gain except on a few AAA titles.
Cinders: - i7 4790K (4.5GHz) - Gigabyte Z97X-SOC - 16GB Klevv DDR3 1600MHz - EVGA GTX 980Ti ACX2.0+ (1548MHz Boost) - EVGA Supernova 850GS - NZXT H440 Orange/Black (Modified) -
Unnamed System: i5 4690K (4.2GHz) - MSI Z97I-AC - 8GB G.Skill DDR3 2400MHz - EVGA GTX 950 SSC - Raidmax Thunder V2 535W - Phanteks Enthoo Evolv ITX
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5758069
I think i'll just sell my current motherboard and cpu and get an i5. What motherboard would you suggest without going overboard? Thanks
Which i5 are you looking at getting? If 4690K then any cheap Z97 board for solid overclocking. Asus Z97-A is a solid pick, or the Asrock anniversary.
Locked i5? Any H81/B85 or H87/97 boards are fine. What price range are you looking at for the motherboard?
Also details like what country you live in, whether you live near a microcenter, etc. These are all important details we need to know to give more accurate suggestions, if you please.
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5759129
So I am looking to take my current ATX build and putting it into an mATX or mITX case for better mobility for lan parties without giving up the great airflow and performance as my current case.
I have an AMD fx 8320 with 2 slots of ram a standard hard drive and will also be getting an ssd and would be upgrading to either an r9 280x or r9 380.
A single 120mm cpu liquid cooling block is also in my build but I would be willing to change that if there is a better cooling solution for a small build like this.
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5762463
I live in Iceland and i don't think there's any international techshop except a website some dude just started called techshop.is and he buys pc parts from other countries and sells them cheap here. But i think i can get any part from any of the local pc stores around. My budget would be around 350-400 might change depending on how much i can get for my current cpu and motherboard.
The Intel equivelant of the FX 8350 price is the i5 4460 wich is about 230 USD
Also one question, i have a Gigabyte motherboard and AMD cpu do all motherboards only support AMD or Intel?.
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5767608
Intel and AMD have their own motherboards for their products; they are not interoperable.
Like I was saying earlier, if you can hold off on getting anything for a few more months until you can get an unlocked i5 (4670k/4690k) then that would be best and offer a good amount of longevity to your system. It's hard for me to find pricing and availability in Iceland (I'm in the US).
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5767737
If you have a cheap board you cannot put a FX-8350 into it anyway so a swap could be what you want also. :P
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5767922
Would the i5-4690 be a lot worse than the 4690k? I'm not looking to doing any overclocking.  You can look at prices for the main tech stores in Iceland on "vaktin.is" (prices are in Icelandic Kr) you can see the price difference there.
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5768997
If you don't plan to overclock the 4690 is the best i5 you can get; but at that price you'd be better off getting a Xeon 1231v3 and pairing it with an H87/H81 mobo. It's clocked the same as the 4690 but has hyperthreading, but no iGPU. Very solid if you can get it around the same price of the 4690 (which it normally is).
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5769259
I think the Xeon products are extremely overpriced and rare here. Am i not getting my moneys worth if i get the i5 4690 and don't overclock it?
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5769289
Nah, it's still an incredibly strong CPU for the money that will last you a good many years. The benefit of going with the 4690K is if you ever decide to get into overclocking you have that option. Generally they aren't that far apart in price ($5-$10?) And by overclocking you can squeeze a few more years out of your system without needing an upgrade. You'll see quite a few people in here using 2500K processors because they just flat out last through new generations.
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5769352
I guess i'm going with the i5-4690 since i don't think i'll get into overclocking yet and i'm not really looking for a cpu that lasts 5 years, i'm going to want to upgrade to the flashy stuff as soon as i'm making real money and start fiddling with overclocking. What motherboard would be a decent fit for the 4690?
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5770390
The price is definitely worth it. Go for a 4690k or 6600k. If you do more than gaming go for an i7
The Brokish Boy v1: CPU: i7-8700k GPU: MSI Gaming X GTX ti MOBO: Asus ROG Maximus X Code Ram: G.Skill Trident Z 4x8gb 3200mhz DRIVES: 2x3TB WD Black , 500gb Samsung 850 EVO SSD, 500gb 970 EVO SSD Case: be quiet! Dark Base Pro 900 Black Headphone: ATH-MSR7 Mic: Blue Yeti Monitors: 27" BenQ GW2765 1440p; IPS, 27" Acer Predator XB271HU 1440p; VA
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5770396
You have some options. An H81 board like this would work fine.
Or a Z87 board along these lines would work too.
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5770680
I didn't find a Z87, only the ASUS-Z97K and it's a 167 USD here and i think that's within my budget. Is the Z97 K fine or is that overkill?
https://linustechtips.com/topic/428646-cpu-purchase-please-help/#findComment-5775468
