Aftermarket Headphone MIC
if I was at home I'd do a search for you but I often see headworns for as low as $12 that have a 3.5mm jack
Studying Software-engineering but too stupid to use amazon search...
There was something I saw called the moov mic or something, and it was essentially a cheaper version of the modmic. Hopefully you'll have luck with that!
Also, I'm not sure if it does, but a vmoda boom pro mic *might* just work on your headphones.
That does look kinda nice though I can only find it on Amazon US
You can get a standard desktop or generic lapel mic if you want.
Likewise if your headphones have a removable cable you can use a BoomPro.
This nearly does look like a perfect solution, unfortunately the HD558 use a smaller 4-pole version of the standard headphone jack (and I've always wondered why, since on the other end it is a conventional 3-pole 1/4 inch jack...
However, I fiddled around a little and got it to work again, though I'm not quite happy to use both onboard and additional sound card in parallel, but well.
Yet, thanks for the recommendations, I will definitely consider some in the near future when getting a replacement.
