Adding a carrying handle? (Need modding advice)
Go to solution Solved by Mnpctech,
Unfortunately all of the cases you suggested have plastic or exterior panels that "pop-off" with push tabs, so not good candidates for adding handles. Based on what you listed, and if you want to add bolt-on handles, I suggest looking at a MATX tower with steel or aluminum exterior top panel.
Here are some suggestions
Fractal Design Core 1300
Silverstone Temjin TJ08B
Cooler Master N200
Corsair 350
and Thank you for the shout out guys!
edit, we just finished making these machined billet pc case handles, http://mnpctech.com/pc-case-lan-party-gaming-carry-top-server-tower-handles/billet-grooved-handles.html
computer_case_lan_handle_billet_mnpctech
cooler_master_n600_mnpctech_pc_handles.j
Hello, and thanks for reading this already!
I'm looking into some good Micro-ATX cases. I prefer Micro-ATX as a motherboard size because it still has 4 RAM slots, 2 PCI-E x16's, but is still portable.
Now, I want to make a Micro-ATX case extra portable.
I'm looking into the AIR 240, Fractal Design Node 804 and the Phanteks Enthoo Evolv. Is there a relative safe way to add a carrying handle too them? And what materials should I use?
Yes, I am insane.
Thanks in advance!
Basic guide to CPU's!
If I said I were 14, you would call me a kid. If I say 70, you’ll entitle me too old. If I say 20 you say I’m inexperienced and if I say 40 than I'm too boring.
龴 ͡ↀ ◡ ͡ↀ龴#locked( ͡͡ ° ͜ ʖ ͡ °)
https://linustechtips.com/topic/424761-adding-a-carrying-handle-need-modding-advice/
Well the air 240 could be a bit of a problem with the top panel just being held on byy two screws really but here is a shoutout to @Mnpctech
Here are some handles!
[spoiler=Blue^3http://linustechtips.com/main/topic/388528-blue3/ I5 4690k | Asrock Z97 Pro4 mATX | RAM: Corsair Vengeance (2x4GB) Blue Edition and Corsair Vengeance (2x4GB) Black Edition | GPU: XFX DD R9 390x | PSU: Corsair AX760 | SSD: Samsung 840- 120GB | Hard Drives: 2x1TB WD Blue | Watercooling Kit: XSPC Raystorm 240
Cooler Master N200
Corsair 350
17 years of helping you void your warranty
Cooler Master N200
Corsair 350
Will take a look at them! Thanks a lot for the suggestion!
