When monitor goes to sleep, F@H slows down?
Solved by Lays,
U go to power options and set it to high performance. Then set display turn off in as less time as possible. Also turn of the monitor manually if you want full power savings. GPU won't be slowed again
I've never encountered this issue but I also have my monitors facing my bed, I just manually turn them off as the light from the LEDs are enough to bother me anyway. There may be something in the power management controls that could help you.
The high performance setting didn't fix it, but I remembered Precision X has "k boost" that forces the gpu into its max speeds and locks it there.
That fixed it!
