Full speed fans at startup
S3NTI3NT
Hi,
Whenever I turn my computer on, my case fans go full speed at startup. The fans are connected to my motherboard which is an Asus P8Z77-V Pro. Is there a way to stop that from happening with BIOS or anything? THanks
Not to my knowledge.
CPU: i5 4430 PSU: XFX 550w Ram: 8gb Patriot Viper 1600mhz
Motherboard: MSI H87M-G43 Case: Fractal Design Define R4
SSD: 840 Evo 250gb, 512gb MX100 GPU: MSI GTX 980TI Gaming Cooler: Hyper 212 Evo
No
<p>Wires Suck :angry:
!fY0|_|(4|\|R34[)7#!5PMM37#3(0[)3:1337 70833|\|73R3[)!|\|49!\/34\|/4Y 4|\|[)93741!f3
Don't think so since I don't see any settings in the bios from my experience that fixes this.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
A lot do. My board does the same. Although for only a few seconds, yours does it until you boot into OS?
Error: 410
My motherboard does the same. Why does it annoy you? It's only for about 2 seconds isn't it?
EDIT:One way to solve it is to simply not connect them to your motherboard. Get a fan controller.
Weird thing is even my sentry mix 2 fan controller does it with all my fans on startup also..
No it's kind of a standart protocol , it prevents dust and helps the fans live longer to my knowlege so it's actually good for the pc.
Interested in Business and Technology
I believe every mobo does this on bootup, so nope :p
Console optimisations and how they will effect you | The difference between AMD cores and Intel cores | Memory Bus size and how it effects your VRAM usage |
How much vram do you actually need? | APUs and the future of processing | Projects: SO - here
Intel i7 5820l @ with Corsair H110 | 32GB DDR4 RAM @ 1600Mhz | XFX Radeon R9 290 @ 1.2Ghz | Corsair 600Q | Corsair TX650 | Probably too much corsair but meh should have had a Corsair SSD and RAM | 1.3TB HDD Space | Sennheiser HD598 | Beyerdynamic Custom One Pro | Blue Snowball
it is a voltage POST test.. all modern mobo, sub-systems do this.. run the fans off
a PSU directly and that won't happen. sometimes can be a bit loud..
airdeano
no the fans do that because the motherboard has to get a temperature reading first for the fans to slow down..it takes a few seconds for it to get a reading
just connect them all to the PSU directly and use 7V adapters ;)
AMD FX8320 @3.5ghz |  Gigabyte 990FXA-UD3  |  Corsair Vengeance 8gb 1600mhz  |  Hyper 412s  |  Gigabyte windforceR9 290  |  BeQuiet! 630w  |  Asus Xonar DGX  |  CoolerMast HAF 912+  |  Samsung 840 120gb
2 WD red 1tb RAID0  |  WD green 2tb(external, backup)  |  Asus VG278He  |  LG Flatron E2240  |  CMstorm Quickfire TK MXbrown  |  Sharkoon Fireglider  |  Audio Technica ATH700X
#KILLEDMYWIFE
Does it bug you? It only happens for like 3 seconds lol
i had the same with my previous PC and i was always like "Welps ok it works" when my PC died the fans didn't start at full speed and that was a signal that something was wrong!
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
As far as i know, the fans spin in reverse to expel dust etc. AFAIK its normally limited to GPU and CPU fans but it may be possible your case fans are doing it too.
