4 pin headset cable (male to male)
Solved by ShearMe,
but what will a male to male get you that a connector wont?
unless you plan to just strip the headphone cable and tape it to the new cable.
not something I would do, as I would be to worried about a wire slipping and a short happening.
I think the cable is detachable, brah
EDIT: Oh, hey, OP. I just read this on their website:
Is cord plug end 2.5 mm or 3.5 mm? Need to replace damaged cord.
1 month, 1 week agobyHeatherThe SLYR utilizes a 3.5 mm cable. Customer Service can sell you a new one or hook you up with a new one in the case of a warranty.1 month agobyIsaac_SKDYadmin
