Mini ITX Build Thoughts and Tips
Solved by PineappleHolidays,
Building a new PC and want to know if theres anything I could add or improve.
Processor Intel Anniversary Edition G3258
Motherboard MSI H81I
GPU Asus GF GT610
RAM Kingston 4GB DDR3 HyperX
HDD Toshiba DT01ACA100 1TB 7200RPM SATA3 32MB
Fans Deepcool Blue LED and CPU Fan
Case Apex M1008/Golden Field Mike 210 Same case different brands though I think Golden Field makes them as they are based in China and Apex resells as it is more expensive.
Using PSU that comes with the case.
Budget 300€.
Just don't get a GPU and save that money,
Use that to get a psu that can handle a gpu later
