Power supply recomandation request.
Go to solution Solved by Delusional Phil,
seconded ...
@STRMfrmXMN ...
Get SeaSonic , preferably the 620W version of the M12II
All EVGA PSUs are good... he knows his wattage as he listed it in his other thread...
Not really. They do have some bad ones like the G1 series.
It's like recommending Corsair, when they have a wide range of PSUs from different OEMs.
seconded ...
@STRMfrmXMN ...
... Life is a game and the checkpoints are your birthday , you will face challenges where you may not get rewarded afterwords but those are the challenges that help you improve yourself . Always live for tomorrow because you may never know when your game will be over ... I'm totally not going insane in anyway , shape or form ... I just have broken English and an open mind ...
After 2 posts and a moment of thinking, I realised it was better to just ask for a recomandation on a PSU, Also to ask if the B700 from coolermaster is any good.
 The Rig i'm trying to build is up with a R9 380 4GB and a FX 8350.
EVGA G2 750W
XFX
SEASONIC
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
