What TIM is everyone using ?
im going to water cool my CPU and my GTX 780 and just looking for the best TIM to use  :unsure:
Will be using EK Blocks for CPU and GPU
Thanks for any suggestion   :)
CPU 5820K @ 4.5Ghz 1.295V,Motherboard Asus X99-S, RAM 16Gb TeamGroup Elite GPU Msi Gtx 780, Case Fractal Design Define R5 , Storage Samsung SM951 256GB M.2 , Samsung 840evo 250Gb, Wd Green 1TB, PSU EVGA 850w G2 ,Cooling Fully Custom Water Cooling Loop Sound Stealseries Wireless H
https://linustechtips.com/topic/40830-what-tim-thermal-material-is-everyone-using/
I prefer Arctic Silver 5. It's the cheapest and best one I can get from our local etailer within a day.
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
same here :P
OK thanks for all the suggestions  i have been told that ic diamond is good ill try that for the CPU and if the ek stuff is good ill use that on the gpu is it all none conductive
No poll?
I'm using artic mx-4
        Sager NP9370EM - I7 3630QM - 680m 1045Mhz - 8gb 1600mhz ram - 240gb msata 750gb hdd
how do u start a poll
Hardware secrets have a table of their test results with many thermal compounds. Keep in mind, the error margin for their test result is 2 degrees (so difference of 2 degrees is negligible).
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-January-2012/1468/5
CPU:Intel 3770k Motherboard:Gigabyte z77x-ud5h GPU:Gigabyte GTX 660 Ti Ram:Kingston HyperX Blu 16GB Storage:Crucial M4 128GB+Seagate Barracuda 1TB Case:Zalman Z11 Plus PSU:Corsair TX650 Cooler:Noctua NH-D14 Fans:Noctua NF-P12+ Silverstone AP123 Keyboard:Corsair K90 Mouse:Corsair M60 Monitors:Dell U2412M+U2312HM
I use Noctua NT-H1
CPU: i7 2600 @ 3.4 GHz | GPU: MSI Radeon HD 7950 Twin Frozr 3 @ 1150 MHz core/6300 MHz memory | Motherboard: Some crap OEM H67 mATX board | RAM: 16GB Patriot G2 Series Division 4 @ 1333 MHz | SSD: Kingston HyperX 3K 120GB SSD | HDD: 2TB Seagate Barracuda | Case: Fractal Design Define R4 Windowed | CPU Cooler: Noctua NH-L9i | Mouse: CM Storm Inferno | Keyboard: crap OEM keyboard (Soon to be replaced with a CM Storm Quickfire TK) | Headphones: Audiotechnica ATH-M50's | Speakers: Corsair SP2500's
I have the Arctic silver 5, but debating if I should buy a IC diamond.
Desktop: Intel 4770k - 12GB Vengeance Pro 1866Mhz RAM - Asus Maximus VI Formula Mobo - Asus Strix 970 SLI - Cooler Master V850 PSU -  Nzxt Phantom 630 Case  - 1TB WD HDD - Samsung 840 Evo 250GB SSD - Nzxt Kraken X60 - 24" Asus VG248QE 1080p Monitor - Logitech G35 Headset -  G502 Proteus Core - Logitech G710+ Keyboard - Nzxt Hue - Windows 10
Not worth it.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
I use Noctua NT-H1
<p>PC Spec: Fractal Design R4, Asus Maximus V Gene, Intel i7 3770, BeQuiet Dark Rock Pro 2 CPU Cooler, 16GB Mushkin Silverline RAM, MSI GTX 660, Corsair AX860i PSU, OCZ 120GB SSD, 2x 2TB Seagate Barracuda SATA III HDD's.
To start a poll, go to your original post and click Edit. Then click Full Editor. To the right, you should see options to add a poll.
