As a first work to put on dA, I made this, which is actually my first legit flat design: (updated so it's centred xD)
What do you think? any critique accepted ^.^'
Computer ----- CPU: FX-6300 | Mobo: GIGABYTE GA-970A-UD3P | RAM: 2x4GB 1600MHz/CL9 | GPU: MSI R9 270X OC | Case: Corsair 760T Black | Storage: 2TB WD RE4 | PSU: EVGA 750W Bronze | Display: Acer 21.5" 1080P | CPU Cooler: Hyper 212 Evo | OS: Triple boot - Arch Linux, Windows 7 Ultimate, OS X Mavericks
Other Possesions:
Phone: Samsung Galaxy S4 Verizon on FamilyMobile, root/flash KitPop ---- Other phone: HTC One M7 Sprint Bad ESN, forgot the rom but root/flash 5.0.0 ---- Tablet: Hisense Sero 7 Pro, forgot the rom but root/flash 4.4.4
https://linustechtips.com/topic/406928-i-made-a-thing/
Did you go to school for that?
https://linustechtips.com/topic/406928-i-made-a-thing/#findComment-5483709
The shadow on the checkmark is coming off the wrong place...it should be at the lefthand tip, not corner
https://linustechtips.com/topic/406928-i-made-a-thing/#findComment-5483734
Nope. Just a bunch of failures and research. :P
Yeah, I was a bit confused when I was making it, so I googled long shadow checkmark, and it didn't really shed much light on it. Thanks o3o
What program did you used?
Just GIMP. I should've used inkscape (in combination with gimp), but my knowledge of how to use it is very limited.
I too made a thing.   :D  A window thing!  A very disappointing thing!  Cuz I could have made this into something useful like a currency or unit converter!
Oh, and I do like the art OP.  However, I feel the monitor isn't super centered.  It's driving my OCD crazy.
Nice thing! :D and OH. MY. GOD. You're right. It isn't centred, there are six more pixels of space on the right side. I wonder how that happened. <.<
almost looked like google's material design
Actually, the check mark icon is from material design X'DDD
Other Possesions:
https://linustechtips.com/topic/406928-i-made-a-thing/#findComment-5487659
I like it!
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/406928-i-made-a-thing/#findComment-5487688
