Hey guys. I am new to the forums but have joined now because I am finally going into pc gaming.
I am purchasing my components for my PC pretty soon and will update this post with a list of the components
that I make my final decision on.
Right now I am a bit nervous going into my first build. I have watched numerous build guide videos by both linus and
many other YouTubers. I am making this post today to ask for some extra tips and tricks for doing my first build.
I have purchased some anti-static wrist straps, a multi-bit tool kit and have my other essential tools.
Any advice would be very appreciated.
https://linustechtips.com/topic/406464-tips-for-my-first-build/
snip
So.... The PC parts? It does help.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/406464-tips-for-my-first-build/#findComment-5477818
Some connectors will require quite a bit of pressure; I was shocked how hard some of the parts were to put in, as the videos make it look really easy. That being said, if it does take some decent pressure, double check that its in the right place the right way before doing anything drastic.
https://linustechtips.com/topic/406464-tips-for-my-first-build/#findComment-5477821
You're probably more prepared than I was doing my first build. Honestly, you'll be fine. It's not as hard as you think, and  this is coming from a guy who just built his first computer 6 months ago.
Useful threads: Code of Conduct || Unofficial LTT Beginners Guide || Forum FAQ
CPU: Intel Core i5 4440 GPU: GTX 760 MOBO: Asrock Z97 Anniversary RAM: 8GB Adata @ 1600 Mhz Case: Define R4 SSD: Kingston V300 128 GB
HDD: 1TB Seagate Barracuda NAS: 3TB Seagate Barracudas in RAID 1 PSU: EVGA 600B (600W 80+ Bronze) Display: LG 23MP75 (1080p IPS @ 60hz)
https://linustechtips.com/topic/406464-tips-for-my-first-build/#findComment-5477824
Oh and.... Stay calm or at least try not to, panic will make things worse. Like @Biferony said, some parts do need some pressure to install, if you're not sure on what you're doing, try reading the manual. It helps you step by step on how to install the parts to the Motherboard.
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/406464-tips-for-my-first-build/#findComment-5477829
Some connectors will require quite a bit of pressure; I was shocked how hard some of the parts were to put in, ass the videos make it look really easy. That being said, if it does take some decent pressure, double check that its in the right place the right way before doing anything drastic.
Especially RAM for some reason. Don't be afraid of the board bending a little. It'll be fine.
https://linustechtips.com/topic/406464-tips-for-my-first-build/#findComment-5477831
For a first timer, just keep your manuals around they can be helpful to know which plugs do what, and which screws to go with what.
Also if you can get your hand on a magnetic parts tray that will help you lose your small parts, and a magnetic tip screwdriver is a life saver.
As for actually building it, if you've watch the videos there probably isn't much more to say, just be prepared for cabling to be annoying as fck, that's really the only 'hard'/long part, everything else should be pretty easy just take your time with it
i5 4690k | GTX 980Ti G1 Gaming | 16GB RAM | MSI Z97 Gaming 7 | NZXT Kraken X61 | 850 EVO 250GB x2  | 1TB 850 Evo NZXT Noctis 450 | EVGA 750W 80+ Gold
 Ducky Shine 3 TKL (Browns) | LG 34UC87C | Logitech MX Master ATH-M50x's + DT990 Pro's
https://linustechtips.com/topic/406464-tips-for-my-first-build/#findComment-5477834
Well here are some tips.
  1. Remove all the things when building (drive-cages, side panels etc.)
  2. Don't eat whilst building. I learn't this the hard way, I had Pizza on my heatsink.
  3. Start with all of your tools
  4. Rout your cables in the nearest grommet and plan out your cable management.
amnerd  B) Linux enthusiast.
  • CPU: Intel i5 4690k @3.5ghz  Motherboard: MSI U3 Plus Z97 GPU: Radeon R9 270x 2gb OC HDD: WD Green 3tb SDDs: Samsung 120gb, Kingston V300 120gb Case: Fractal Design Define R5 PSU: Corsair V650 Fans: Corsair AF14 x4 CPU cooler: Hyper 212 EVO (Upgrading soon)
https://linustechtips.com/topic/406464-tips-for-my-first-build/#findComment-5477836
Wait for ALL of your components to arrive before putting it together. Don't even take them out of the box. You'll be tempted to, but you'll learn the hard way that this is a bad idea if you do. I certainly did, and it made my build much more frustrating
https://linustechtips.com/topic/406464-tips-for-my-first-build/#findComment-5477858
Also CPU and GPU, needs a bit of pressure to install.
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/406464-tips-for-my-first-build/#findComment-5477865
GPU not so much. The CPU retention arm is another story though.
https://linustechtips.com/topic/406464-tips-for-my-first-build/#findComment-5477871
Yeah GPU not much, the CPU.... Because some just afraid to break the CPU, because when I built my first PC, I was afraid to put the CPU to its socket.
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/406464-tips-for-my-first-build/#findComment-5477892
I haven't finalized these component choices (might change cpu cooler if I find a better one for same price of around 30-35 euro) but here is the general look of
my build:
Case:   Corsair Graphite 780T Black
CPU:    Intel Core i7 4790K
GPU:    MSI GeForce GTX 960 4gb
MB:      Gigabyte Z97-X Gaming-5
RAM:   Corsair Vengeance Pro 16gb (2x 8gb) 2400Mhz
HDD:    Seagate 2TB Barracuda
CPU Cooler:    Arctic Cooling Freezer Xtreme Rev.2 Universal CPU Cooler
Fans:     Corsair Air Series sp120 Red (x3)
PSU:      Corsair 750w CS750M Semi-Modular 80+ Gold
https://linustechtips.com/topic/406464-tips-for-my-first-build/#findComment-5478029
my build:
If the intention of this system is purely gaming, swap the 4790K out for an i5 4690k, and dump the money saved into a better GPU.
https://linustechtips.com/topic/406464-tips-for-my-first-build/#findComment-5478368
Welcome to the forum!
Some tips:
Don't worry too much. Just be gentle and careful with your components, and all should go well.
Go in a step by step process. Just like the build guides from Linus and stuff.
Cable management is key to making a system look good. But so is component choice (yours looks pretty good, although I would get 4690K and a better GPU as @nicholician said, and also drop some cash on an SSD, as it makes the system feel A WHOLE LOT FASTER).
It may seem scary or like you're going to mess up, but hey, a five year old could build one. As a great man once said:
JUST DO IT!
https://linustechtips.com/topic/406464-tips-for-my-first-build/#findComment-5478408
I will also be using the system for video editing, photo-shopping and college work as I am a games development student.
https://linustechtips.com/topic/406464-tips-for-my-first-build/#findComment-5478633
If you really want to fly in video editing, you'll need more cores such as what is found on the X99 platform, but I'm not sure if that's really in your budget.
But you have to get an SSD as @byalexandr said. It really does make the system feel so much faster
https://linustechtips.com/topic/406464-tips-for-my-first-build/#findComment-5478941
just dont be me, okay? (forgot to screw in a 90° fitting (it was semi-threaded in, just not far enough for tje o-ring to seal) and i spilled coolant all over my carpet...)
My pc:
http://pcpartpicker.com/p/dvcw23
(Black Glacier)
My server:
Dual xeon x5679 processors, 24gb of ECC memory, Nvidia quadro 295 NVS and 48tb of storage.  (z600
https://linustechtips.com/topic/406464-tips-for-my-first-build/#findComment-5481101
Damn. That must have really sucked bro, sorry to hear that
https://linustechtips.com/topic/406464-tips-for-my-first-build/#findComment-5481964
