help need it
Go to solution Solved by JoaoPRSousa,
i see, but why other builders in youtube put about 3 videocards in their pc? its that really nececary?
You really don't need to get 3 GPUs. IF you really want, you can throw in another 980 Ti, yet again, you don't need to.
Hello every one,
i have being planing to build my pc for a while and i have learn alot in the past few months in youtube and others sites and i would like to know if everything that i have put together its compatible before i buy it, can some body help me with that?
https://www.amazon.com/gp/registry/wishlist/3VVWUBNUSEFFE/ref=cm_sw_em_r_wsg_P0xNvb4PAC4HY_wb
Hire is my "wish list" were i have petty much everything listed, i would appreciate some help.
Thanks.
https://linustechtips.com/topic/403135-help-need-it/
@Danielmeza Your motherboard only supports DDR4 RAM, you chose DDR3. Also, that power supply is for basic builds, I would recommend using something like an EVGA 750 G2. Mainly worry about changing out the RAM to DDR4, since the X99 platform only supports that. Everything else is good and should be compatible.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/403135-help-need-it/#findComment-5435899
you have DDR3 RAM that motherboard only supports DDR4 RAM, and I would get a 750 watt power supply to have some leg room and 80 plus gold fully modular. other than that looks good
      CPUIntel Core i7-4790K 4.8GHz Moherboard: MSI Z97 SLI Krait Edition Memory: HyperX FURY White 24GB DDR3 1866MHz GPU: Asus GTX 970 Turbo
             PSU: EVGA SuperNOVA 750w SSD: Crucial MX200 250GB HDDWB Blue 1TB Monitor: (2x) BenQ GL2460HM 24-Inch Case: NZXT S340 White
https://linustechtips.com/topic/403135-help-need-it/#findComment-5435973
Your case does not have any 5.25" bays, that CD drive wont work.
amnerd  B) Linux enthusiast.
  • CPU: Intel i5 4690k @3.5ghz  Motherboard: MSI U3 Plus Z97 GPU: Radeon R9 270x 2gb OC HDD: WD Green 3tb SDDs: Samsung 120gb, Kingston V300 120gb Case: Fractal Design Define R5 PSU: Corsair V650 Fans: Corsair AF14 x4 CPU cooler: Hyper 212 EVO (Upgrading soon)
https://linustechtips.com/topic/403135-help-need-it/#findComment-5435974
First off, https://www.pcpartpicker.com/ is a much better tool for planning PCs.
Second, you don't need the thermal paste, the cooler you have comes with some. Third, the RAM you have listed is DDR3, not DDR4. 2011-3 socket CPUs only run on DDR4 memory. Fourth, the Noctis 450 doesn't have any 5.25" drive bays. therefore you would not be able to install the DVD drive. And last, you need a power supply. It needs to be ATX size, be at least 500W for the system you are planning, and you want one that is 80 Plus rated, and modularity helps a ton. Again, use PCPartPicker. It will correct your mistakes you are making and find the cheapest places you can get these components.
Edit: I see you have a power supply, but for the kind of components you plan on purchasing, I would recommend a better PSU.
https://linustechtips.com/topic/403135-help-need-it/#findComment-5436036
Second, you don't need the thermal paste, the cooler you have comes with some. Thrid, the RAM you have listed is DDR3, not DDR4. 2011-3 socket CPUs only run on DDR4 memory. And last, the Noctis 450 doesn't have any 5.25" drive bays. therefore you would not be able to install the DVD drive. Again, use PCPartPicker. It will correct your mistakes you are making and find the cheapest places you can get these components.
3rd party thermal paste isn't needed, but it sure saves you a pain in the ass if you ever need it later down the road for whatever reason.
https://linustechtips.com/topic/403135-help-need-it/#findComment-5436050
Similar to what you said, I also see a problem with your RAM. The motherboard that you have selected does not support the 1600 MHz RAM that you have selected as well as the memory not supporting use with the X99 Chipset. I would upgrade to some DDR4.
For your LG drive only supports Windows XP, Vista, or 7. I might be concerned about this.
I also see (like @byalexandr) that your case doesn't have drive bays that would support the Blu-Ray drive that you have selected.
So thanks for reading guys, if this post sucked, I'm not sure what you can do, but if you liked it, go 'head and hit that like button, or maybe add me as a friend. Otherwise, go subscribe to LinusTechTips on YouTube, follow them on Twitch, follow @LinusTech on Twitter, and support them by using their affiliate code on Amazon, buying a cool T-shirt, or supporting them directly on this community forum.
https://linustechtips.com/topic/403135-help-need-it/#findComment-5436052
Here, I fixed it for you: http://pcpartpicker.com/p/njhZ7P
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($378.99 @ SuperBiiz)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler  ($111.99 @ Amazon)
Motherboard: Asus X99-DELUXE/U3.1 ATX LGA2011-3 Motherboard  ($389.99 @ Amazon)
Memory: Corsair DOMINATOR Platinum 16GB (4 x 4GB) DDR4-2666 Memory  ($269.99 @ Newegg)
Storage: Samsung 850 EVO-Series 1TB 2.5" Solid State Drive  ($377.99 @ Amazon)
Video Card: Asus GeForce GTX 980 Ti 6GB Video Card  ($614.18 @ Amazon)
Case: NZXT Noctis 450 ATX Mid Tower Case  ($134.99 @ Micro Center)
Power Supply: NZXT HALE90 V2 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($143.98 @ Newegg)
Total: $2422.10
Generated by PCPartPicker 2015-07-08 16:31 EDT-0400
ALSO, please move this thread to New Builds and Planning.
Nice build, though. Liking the color scheme.
https://linustechtips.com/topic/403135-help-need-it/#findComment-5436098
There's no reason you should use the entire tube for the inital application. My Seidon 120V came with an entire tube and I only used a pinch of it.
https://linustechtips.com/topic/403135-help-need-it/#findComment-5436103
The H100i GTX doesn't come with a tube. It comes with a slab of thermal paste pre-applied to the copper cold plate.
https://youtu.be/HUz88inukEM?t=1m20s
https://linustechtips.com/topic/403135-help-need-it/#findComment-5436121
Interesting. I thought for what you pay they would give you an entire tube of thermal paste. Even my $50 Cooler Master Seidon 120V came with an entire tube.
https://linustechtips.com/topic/403135-help-need-it/#findComment-5436141
It's only Cooler Master that does that AFAIK (Noctua and others too), most likely since they manufacture thermal paste and doesn't cost them much extra to include it with their coolers. Corsair on the other hand would have to source thermal paste from a third party if they wanted to supply excess with the cooler. Though I'm just going by my logic and have no real evidence to back it up.
https://linustechtips.com/topic/403135-help-need-it/#findComment-5436174
Well if Corsair is such a large company that is almost, if not as big as Cooler Master I don't see why they couldn't take the extra step. Interesting thing, though. I have never owned any Corsair products, only Cooler Master, so what do I know?
https://linustechtips.com/topic/403135-help-need-it/#findComment-5436209
Other than things the other people have said, I really hate that case but I guess if you like it go for it. I wouldn't buy the 980 ti at that price. Retail price is $650 but stock is low so you have people selling it for higher than that. 2 980s won't be a bad option either if you can't get a 980 ti. It's probably more appropriate for 4k anyway. A single 980 ti will still struggle to get over 60 fps in modern games. Also for the monitor, I would get the Dell P2715Q instead because it's IPS.
Also the MSI X99S SLI plus motherboard will be a better option at half the cost. That Asus motherboard is great looking but not worth the money. You should not be spending more on your motherboard than the cpu.
https://linustechtips.com/topic/403135-help-need-it/#findComment-5436210
Welcome to the forums @Danielmeza :D
Always follow your topics, quote or tag us to notify us, and mark the topics as solved when you are done.
X99 platform with that PSU? Ok...  :wacko:
What are you going to use the PC for?
Is your budget 3000$?
Do you have any preferences? Color scheme? Form factor?
"an obvious supporter of privacy"
https://linustechtips.com/topic/403135-help-need-it/#findComment-5436237
That's actually pretty common. Only companies that make their own thermal paste will usually give a whole tube of it.
https://linustechtips.com/topic/403135-help-need-it/#findComment-5436239
Haha, true. Pretty soon Corsair is going to have Corsair Gaming thermal paste with their tramp stamp on it. Maybe even tell you to apply it to your processor by drawing the logo with paste.
https://linustechtips.com/topic/403135-help-need-it/#findComment-5436286
X99 platform with that motherboard? Ok...  :wacko:
I think you mean that X99 motherboard with the lowest end X99 processor. With that board, I'd go a 5960X. It also looks like he is going to game and be editing, why else would you go X99?
https://linustechtips.com/topic/403135-help-need-it/#findComment-5436302
@Danielmeza
I recommend you follow your post so you know that people have answered and are trying to help you.
CPU: Core i7 4970K | MOBO: Asus Z87 Pro | RAM: 32GBs of G.Skill Ares 1866 | GPU: MSI GAMING X GTX 1070 | STOR: 2 X Crucial BX100 250GB, 2 x WD Blk 1TB (mirror),WD Blk 500GB | CASE: Cooler Master HAF 932 Advanced | PSU: EVGA SUPERNOVA G2 750W | COOL: Cooler Master Hyper T4 | DISP: 21" 1080P POS | KB: MS Keyboard | MAU5: Redragon NEMEANLION | MIC: Snowball Blue | OS: Win 8.1 Pro x64, (Working on Arch for dual boot) |
https://linustechtips.com/topic/403135-help-need-it/#findComment-5436322
I derped it up. Big time. I meant PSU not motherboard. That's the second time I derp up today. WTF is wrong with me...
https://linustechtips.com/topic/403135-help-need-it/#findComment-5436357
im an amateur editor and one of my pasion is playing videogames, and i have being saving for a wile, actualy my budget it is axacly 4,000, the only factor that worry me at chosing the parts (visual factor) its the color i would like to get a black or a withe tower, but the components and the light i want to atach i would prefer withe
https://linustechtips.com/topic/403135-help-need-it/#findComment-5439409
Motherboard: Asus X99-DELUXE ATX LGA2011-3 Motherboard  ($386.98 @ Newegg)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card  ($699.98 @ Newegg)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($109.99 @ Newegg)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($86.98 @ OutletPC)
Monitor: Asus PB287Q 60Hz 28.0" Monitor  ($539.99 @ Amazon)
Total: $3292.76
Generated by PCPartPicker 2015-07-09 05:43 EDT-0400
You can get the Blu-Ray reader/writer if you really need it.
Other than that, that's what I'd get, you don't necessarily need to spend the 4K$ ;) Tho, you can go with a better CPU...
https://linustechtips.com/topic/403135-help-need-it/#findComment-5440977
Total: $3292.76
thanks man, you have pretty much build my pc, i have only one queston, how far im from geting a 4k computer?
https://linustechtips.com/topic/403135-help-need-it/#findComment-5444930
